20 Most Recent
Dell Streak Smartphone Questions & Answers
Forgot pattern screen lock
if you have forgotten your pattern lock, just
give a few more tries to continue, then a message will display, the OS will
report "attempts exceeded", then enter your gmail address and in the textbox
for password just give value as 'NULL'
this will instantly ask for new pattern lock and you are done.
Process.andriod.com not responding
if its on your phone line check for a dial tone.. if your computer uses your phone line.. shut it off and listen for a dialtone.. if you dont have one inside ..check at the box outside.. if you have one there..then your modem is not working right..need it looked at or replaced..
Sim network unlock pin code
I suggest you can approach
Unlock-zone.com and specify the country, locked network of your Dell Streak mobile.Based on the availability you can get the unlock code along with free instructions.
How can i download utube videos to my Dell streak smart phone
Once downloaded the youtube app from play store onto your phone. Its easy to send vids to email account. Facebook etc. I understand its easy for sharing favorate vids n stuff but hard 2 save best stuff 4urself.try holdin your finger down on somethin 4a while untill an opption comes up. It works 4 all else. Sorry not so much help. Total goodluck 4 ya!!!
Dell streak 5 draw pattern to unlock NO WAY TO TOUCH IN THE SCREEM
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
How do I share internet
you cant. you have to buy the tether service from you provider or you have to root the phone..
Dell Streak can't take photos
go to menu then settings then to sd card & phone storage and on the 3rd line down should read unmount sd card and if it reads something different turn the phone off remove the back cover , battery and then take out the memory card and put it back in again.. i hope this helps please rate and vote if my answer is helpfull..
