SOURCE: Installing Ezonics Web Cam
before you use your web camera, you must install the disc driver to your computer, after you do that, connect your web camera to your pc, then click next and restart...if you do that...i assure you, you will use your camera normally and you can chat with a web cam..=.)
SOURCE: EZONICS WEB CAM
the EZONICS PRODUCTS ARE SH.IT 'cause they haven't a web page where support the software I recommend that trash that web cam and buy a new one, a popular web cam where you can download the drivers at any moment without any problem, and remember to keep a copy of your installation disk, you get mad, crazy, tired when you don't find it
SOURCE: how install web cam without cd
im not sure if your ezcam uses the same driver but you can try using the drivers on this link: http://www.driverfiles.net/USB/Fugi/ezonic-camera-driver/download/page,sh,16312,87,14,.html
SOURCE: No Install Software for Ezonics Web Cam
The drivers are located HERE.
Just scroll down to the Drivers Download part and choose your camera from the list.
Hope this helps.
Please don't forget to rate my solution, thanks!
SOURCE: install A4 tech PK635 M web cam without cd installer
v\:* {behavior:url(#default#VML);}
o\:* {behavior:url(#default#VML);}
w\:* {behavior:url(#default#VML);}
.shape {behavior:url(#default#VML);}
Normal
0
Go to this site and select your product and download your
driver for your webcam.
http://www.a4tech.com/ennew/downloads.asp
Use the quick product locator then select “Web Cameras”
Then under “Downloads,” in the drop down, “Select”
the model number.
Also when it asks you for your Windows Operating Systen, be
sure to select the right one.
Then after completing the download do this.
Disconnect the Camera from the USB port and reinstall
the CD or Downloaded softwareprogram. When the program asks you to
connect the camera to theUSB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to besetup on the program they are to be used with.
Just installing the cameraon your computer does not set it up to broadcast on
messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video
to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/)
set it up as follows:
The camera and audio should function properly. Yourfriends
and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html)
Hopethis helps. Bud
