20 Most Recent Toshiba Satellite M35X-S163 Notebook Questions & Answers
My Toshiba Satellite m35x-s163 needs a dvd driver.
I don't know If I'd trust the site totally. It's a little fishy, but judge for yourself: http://www.driversupdated.com/exact/toshiba.php
9/12/2019 2:00:32 PM • Toshiba... • Answered on Sep 12, 2019
Reset bios
You'll need to find out which screws hold the keyboard in. Usually three or four and are on the bottom of the laptop. After unscrewing them you'll have to pry off the plastic part (carefully) that is just under where your laptops screen is. Then you will see two, three, or four screws that hold the keyboard in. Unscrew those, then gently lift up the keyboard and you should see a small round button battery somewhere on the exposed part. That is the CMOS/BIOS battery. (Note you might have to take more screws out on the back if the battery is hidden under a part, but usually it is visible and you can get to it) remove that battery for 1/2 hour or longer, and put it back. This usally will reset the bios and its password. Also note tho, that some newer boards that won't work on, and you'll need to buy software especially for reseting the password in the BIOS. Youtube has some 'videos' that advertise those softwares. Try the battery thing first tho. If uncomfortable doing that first part to get to the battery yourself, you will want someone who knows how to take apart a laptop to do it for you.
5/28/2013 11:58:09 PM • Toshiba... • Answered on May 28, 2013
Serial number for idm
i need serial number for my PC
3/25/2013 2:38:18 AM • Toshiba... • Answered on Mar 25, 2013
When i connect my toshiba charger and my laptop goes off but i have tried different charger still thesame
Normally this should be a charger issue. I personally use quite a high-end charger. You should consider when you buy laptop charger that the wrong voltage/current could mean your computer can't turn on.However, if you're 100% sure the laptop charger isn't at fault, then I recommend getting it checked out by a repair shop, because it may be a main-board issue where your laptop is actually not accepting the power from the supply, which is potentially terminal.
11/5/2012 2:26:57 PM • Toshiba... • Answered on Nov 05, 2012
Dvd is not detected by my computer
The DVD maybe faulty and needs replacing or it is not making proper electrical connection, try re-seating the DVD drive.
10/16/2012 2:19:33 AM • Toshiba... • Answered on Oct 16, 2012
Need to replace the keyboard
10/5/2012 8:21:17 PM • Toshiba... • Answered on Oct 05, 2012
Missing windows 7 drivers?
FREE - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1039005&rpn=PSA72U&modelFilter=M35X-S163&selCategory=2756709&selFamily=1073768663BRITISH $9.95 http://www.user-guides.co.uk/os/Toshiba-Satellite-M35X-S163/#ToshibaSatellite-M35X-S163win7driverdisk
9/21/2012 3:59:01 PM • Toshiba... • Answered on Sep 21, 2012
Video card for window7
what u want
9/19/2012 1:15:43 PM • Toshiba... • Answered on Sep 19, 2012
Labtop won't turn on
remove battery, plug-into Adapter/Charger.Does it work ?Tallon41
9/8/2012 6:32:25 AM • Toshiba... • Answered on Sep 08, 2012
How do i clean my error on my laptop?
Dear user,So many errors means you have to format your laptop, please back up all data before formatting.
8/31/2012 3:07:15 AM • Toshiba... • Answered on Aug 31, 2012
2answers
How to fix orange blinking light on ethernet
orange blinking on ethernet means that your connection is 10 Mbps and green blinking means 100 Mbpsthere's nothing wrong with it
8/27/2012 7:21:14 AM • Toshiba... • Answered on Aug 27, 2012
How can i use the cam in my laptop?
go to Start->All Programsand look for the web cam program,i don't know what's the program name exactly,it's different in each PCnormally,it's already installed on your operating system,but if you don't find it,then you need to install it manuallyyou can try this onehttp://www.driversforfree.com/omn_ofm_omd_drd/toshiba/satellite/m35x-s163/toshiba-webcam-driver/search.aspx
8/24/2012 4:04:38 AM • Toshiba... • Answered on Aug 24, 2012
I have a toshiba satellite that emits one long beep at start up.
Re-seat the RAM. I think that is the one long beep issue.
7/23/2012 10:06:29 AM • Toshiba... • Answered on Jul 23, 2012
Shift key
You may have to buy a USB or wireless keyboard and bypass the laptops.
7/22/2012 11:03:55 AM • Toshiba... • Answered on Jul 22, 2012
Blue Screen
Most likely your hard drive is either defective or infected. Best approach would be to save your data and reinstall your operating system. If it still occurs then the hard drive is the problem.
7/22/2012 12:17:05 AM • Toshiba... • Answered on Jul 22, 2012
Pls help me find vga drivers for my m40 laptop
You can download thevideo and device drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
7/4/2012 5:40:46 AM • Toshiba... • Answered on Jul 04, 2012
Toshiba Satellite M35X-S163 Notebook Logo
Popular Tags
87 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
s hard drive failure
  • Computers & Internet
