If this is wall/window unit, you can do it but it can be tricky. the fan in window units usually has 2
shafts on either side , it drives fan for both the condenser and evaporator. You basically have to pull the top off, loosen set screw on both blades, remove some screws to move back condenser coil(gently, don't kink tubing) similar process on evap side. Then mount new fan motor, wire it in put fan blades back on in proper position, reassemble unit, test run on bench.
