I was playing and one day i turned it on and the sound worked perfectly but the screen dident come up i bought new cables still nothing so what do i do......... xbox 360 won't show up on screen. The sound is fine. I bought new cables which turned out not to be the problem. Any help?
You can view the link below for the complete solution. i cant post it here as it is too long
http://support.microsoft.com/kb/909335/
Hello!
This is similar to the Red Lights Of Death. But instead of your CPU having a bad connection, it's your GPU. There is a 3 year warranty on the 360, so call Microsoft and get it repaired or replaced. If the warranty seal is broken you can take it apart and replace the x-clamp with 4 screws, 8 fiber washers, 8 steel washers and heat sink paste. Contact me for further instructions if doing it yourself. I hope this helps.
Good luck and happy gaming!!
Try to replace again with another wires. sometimes new wires got factory defects. after you replace it with a new one, test it on their xbox if its correctly functioning after that test it on your xbox. hope that helps sir!
CHARCOIS
