SOURCE: Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
SOURCE: our rv has a dometic rm2600 fridge that smells of
Sorry to give you the bad news. The ammonia smell is the the refrigerant
leaking out. Dometic uses ammonia that is heated and then condensed to cool. It will all leak out and quit cooling.
The fridge is wrecked. There are shops that rebuild the units. Beings as ammonia is corrosive one must assume there may be other leaks ready to appear. There are RV salvage yards that sell good used units.
Again Sorry for your loss.
SOURCE: RM2652 Refrigerator: I have a DM2652 model Dometic RV refer. It is leak...
Dometic Voluntarily Expands Refrigerator Recall
Dometic recently expanded its recall on a population of two-door refrigerators. The original recall included some two-door refrigerators manufactured between April 1997 and May 2003. The new recall focuses on models manufactured between June 2003 and September 2006.
To see if your unit is on the recall list & what to do, try the link below.
If your unit is on the list, DO NOT run your refrigerator on propane until the kit is installed
http://www2.dometicusa.com/recall.php
Is it even lighting up at control panel at top? Have you tested for 12 VDC to back of fridge?
