20 Most Recent Dometic RM2620 Refrigerator Questions & Answers
3answers
Dometic Refrigerator Model RM 2820 Stopped working
Hi Tom,
If your fridge quit working altogether, check your DC fuses in the fuse box, as well as the back of the fridge under the black plastic cover (3 amp). Though the fridge uses LP and 120vac to cool, it is controlled by 12 volts.
5/19/2022 4:28:51 AM • Dometic RM2620... • Answered on May 19, 2022
I have a Dometic RM 2620 fridge, that won't cool. A squirrel got into wiring, I have taken care of wiring but will not work on gas or AC. Spark igniter will no spark either. Any ideas?
Since I don't know what does work I am kind of shooting in the dark. Does the ac heater get hot ? The spark ignitor is part of the control board. But won't work? I assume that you have a user manual but I am including a link to download one. https://www.dometic.com/f6e8a773-69f5-4624-9b35-54e8801da7af.fodoc Note that there are three fuses. B (12V control) and C (120V Heater) on the control board and a thermofuse L located on the stack. If L is good and everything else is good there should be 12VDC on J1 and at Fuse B
1/9/2019 1:57:00 PM • Dometic RM2620... • Answered on Jan 09, 2019
My dometic rm 2612 stops working at least once a
Your 'frige has either; a 12 volt power supply or, a gas flame to circulate the refrigerant gas to cause absorption refrigeration to work; check or, replace your power supply as it 1. holds open the gas valve relay, 2. heats the gas with a heating element.
9/3/2018 9:29:32 AM • Dometic RM2620... • Answered on Sep 03, 2018
3answers
Ammonia smell from rv refrigerator. Not working.
i suggest u take ur rv ammonia refrigerator to ur rv dealer for a replace.. ammonia leaking can result in serious injuries, in tight places...
1/16/2018 4:37:13 AM • Dometic RM2620... • Answered on Jan 16, 2018
0answers
Problem with the electric on fridge not working
Hello Paintinfool3, I have worked on these in the DISTANT past... They are a great CLASSIC design... Working on gas means you are 90 to 95% all good The electric comprises two basic elements only confused because you have both AC & DC modes. Just for simplicity sake the ELECTRIC section (heater & thermostat) section in the BELOW begins with SECTION 63... You need a volt-meter with an OHM scale... (the $9 kind... HARBORFRIEGHT gives away). There is a yes/no trouble shooting guide. Also CUSTOMER CONTACT numbers in the very back. Phone TECH Support at ... 1 (219) 463-4858 Happy hunting!! http://www.nationalserroscotty.org/resources/dometic-service-manual.pdf Support Dometic Mobile living made easy Carnac the Magnificent
4/12/2017 1:30:12 PM • Dometic RM2620... • Answered on Apr 12, 2017
Dometic RM2620 Refrigerator Logo
148 questions posted
Top Dometic Refrigerators Experts
Jay Finke
Jay Finke
Virgil Watts
Mike Cairns
Mike Cairns
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Dometic Refrigerators
Most Popular Question
2 year old rm 2620 fridge stopped
  • Refrigerators
