Nintendo Wii Console Logo
Posted on Jun 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to connect to internet on my wii console but it comes up with error code 51420
Anonymous
Level 2:
Scholar:
  • Expert 55 Answers
  • Posted on Jun 04, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
55
Questions
0
Helped
33193
Points
178
Error code 51420 means The Wii console is not able to connect to your wired router or modem.
Try to do this step hope it will help you plzz rate me tnxx...
  1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
  3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
  5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
  6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
Error code 51420
Error Code: 51420 The Wii console is not able to connect to your wired router or modem.
I cant get to connect to the internet it will give me an error code 51420
Hi there.
This error tells you that the Wii console is not able to connect to your wired router or modem. Please follow the steps in this link to fix this problem.
Thank you!
Trying to hook it with netflix keeps giving me an error code 51420
This should remove the error and allow you to watch Netflix.
2helpful
I cant get the internet to connect to the wii
I'm getting Error Code: 51420 when trying to connect to the internet with the Wii console.
This is our first time trying to make internet connect with the Wii console. I have a USB cable connect from Wii console to the Modem. Any help
Error code 51420 on my wii console. I am trying to establish a connection to the internet. I have a router which is working properly because i can get on the internet now. I have ran my ethernet cable...
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo. LAN adapters not made by Nintendo likely will not work with the Wii console.
I am trying to access the internet to get netflix on a used Wii. It is saying error code 51420. What do I do?
Sometimes this happens because servers go down for nintendo. If this problem persists it might be caused by a third party adapter that is used to connect your wii to the internet.
Unable to connect to internet error code 51420
easy fix i used wii party my system then updated then i went to wii shop and updated again the whole system updated to the 4.3E and now able to use wii shop again
2answers
3answers
Wii Console: error code 51420...
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
