Samsung PCL545R 54" Rear Projection Television Logo
Posted on Jun 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv gets light blueand stays that way...comes back to perfect color the back to blue X-RAy looking it is a samsung pcl545r
Joseph Clark
Level 2:
Scholar:
  • Expert 95 Answers
  • Posted on Jun 03, 2011
Joseph Clark
Expert
Level 2:
Scholar:
Answers
95
Questions
0
Helped
28815
Points
290
Behind the screen, there are three color tubes: Red Green and Blue.
Unfortunately, rear projection screens often have these problems and the tubes do go out after extended use.
Take the television to a TV Repair shop to have this fixed. But in the long run, this may end up costing you a lot more than if you would purchase a new TV. The light tubes are fairly expensive.
1helpful
Samsung PCL545R 54 in. Rear Projection Television
Ur tv have a problems known as a convergence problems,it dead.The tv covergence board must have it 2 STK Convergence ICS and some or all resistors be rreplaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Cannot manually Converge Samsung PCL545R 54 in. Rear Projection Television. Perfect focus doesn't work either.
Try website like Tv repair World.com to buy a whole convergence board to replaced.Samsung/Akai use the same convergence board.
Hi, I just bought a samsung blue-ray. I want hook
i can help with that have you looked on the back of the tv at all the jacks you have look at the color of the jacks some are red and white those are for audio and the yellow is video you need a pair of cables that will conect from you dvd to your samsung that same color on both ends their RCA cables or analog cables
Seeing double red and blue
replace the convergence board. You can get one at the following link.
http://servicemanuals.vstore.ca/
SAMSUNG DLP TV HLR5067W
The main board is more than likely the cause of the trouble. Time for a new TV.
1helpful
Samsung PCL545R Projection TV
Pull out the plug for the TV and leave it out for one hour at least.  Plug it back in and it should be ok.  It will re set itself.
No green or blue color in pictures!
You need to find a qualified servicer. You have component failure.
Look for TV Repair on craigslist or yellowbook.
Craig www.classtorations.com
Bad ghosting of all colours
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Blueand dark when picture should be yellow and gold bright
Well there are many causes for this. In the back of your tv there are three different color projectors. One red, one green, one blue. One or more of them seems to be out of alignment. They can be adjusted but it is recommended to be done by a professional as there are transformers in the back near that area that create the high voltage current needed to run the color guns.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
