Hello sir
i have nokia n70 too ,
you need the battery extander :
Battery Extender helps you extend the standby time of your Series 60 smartphone by up to 30%
you can find it in this page-web
download now
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
dear sir, still if the same,then plz change your battery(lithium ion battery or the battery prescribed for the model,plz note:before changing battery make sure yu buy the battery specified for your cam) thank you...take care
the first suspect is your battery,which is running in low battery....kindly recharge the battery for few hours with the original charger,because the charging volt varies from battery to battery of the same brand and using this universal charger is definitely going to harm ur camera very worse,kindly go for the original charger and charge the battery and then put your camera on........
