Hi If clean light is blinking 7 times then it may be an issue
with heater circuit, door switch or wash pump. If yes then please reset the power
to the dishwasher. After, 5 minutes check if you are still getting the same
error. If yes, then it is a water heating fault. To resolve this error try
pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High
Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi
Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and
then you press the Cancel/Drain button and allow it to completely drain and
reset. Hope this helps... Please post back if you need more
information. Daniel
If this doesn't work then it's an issue with the wash pump not pumping the
water past the heater efficiently or due to lack of water to heat. Please make
sure that heater is not open circuited and is heating the water efficiently.
You'll have to check the heater using a multimeter; the meter should read between
3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then
make sure water pressure is optimum and fill valve is working fine.
Press Normal Wash-heated dry-normal Daniel
wash-heated dry..... If this is not an option then press High Temp - Air Dry - High Temp - Air Dry.......If you
don't have a "heated dry" button, use the "air dry" or "energy saver dry"
button instead. Hope this helps...please post back for further
assistance.
Still could not get the unit to start. Was not sure about the reset sequence you gave me. Here are the Cycles on my machine: Antibacterial
Pots/Pans
Normal Wash
China Gentle
Time Saver
Quick Rinse
Also there are Options:
Hi Temp Scrub
Sani Rinse
Air Dry
I did do the drain cycle, and still the clean light blinks. I wonder if it would be too expensive to fix this unit? Do you have any other suggestions? Thanks.
