Microwave Ovens Logo
Posted on May 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Own a holiday brand stove bought from Lowes in 2000.. Need replacement burners (both front and rear) for stove top. No readable model number. I need to know the manufacturer so I might ascertain how and where to purchase burners. Stove was bought to use with propane gas propane gas in rural community.
Johnny Wright
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 07, 2017
Johnny Wright
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3863
Points
They are made by LG in Korea it says it on the back of my gas stove
Iron
Level 3:
  • Master 3,018 Answers
  • Posted on May 17, 2011
Iron
Master
Level 3:
Answers
3018
Questions
Helped
1670595
Points
10301
  • Holiday appliances are made by Maytag. Here is the link to the Maytag parts list.
  • http://www.maytagpartsonline.com/index.php?main_page=index&cPath=1251_1279
  • There are some burners and element for sales as you go through the parts. This is the absolute best I can provide without a model number. However, being a Maytag, it should be much much easier with the parts list from Maytag I provided. Maytag range parts are universal throughout their models.
Regards, Tony
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
The aluminum burner ring in my holiday propane stove is warped and distorted. it measures 2 1/2" (o.d.) by 1 1/8"(i,d,), can you locate 3 replacement rings for me?
Hello & Welcome to FixYa
You can buy the burner rings from here. Please get back to me if you have any other questions.
Kevin
I am disassembling a Kenmore stove top gas burner to clean under the stove top. To do so you actually need to unscrew the burners, which I've done, but then I need to unhook the spark electrode, which...
The electrode is held onto the burner head with a screw through the mounting tab. They can get crusted over and it's not always easy to see the screw head, but it's there.
Kitchenaid stove top (17 years old) pilot light is out. How can I relight it?
To relight it you need to pick up the top from the front and then relight the pilot that is in the center between the burners with a match or a lighter...
heatman101
2answers
I have a whirlpool stove and one of the burner doesn't work but the light on switch works. What could be the problem and how can I fix. Help pls.
1.TURN THE POWER OFF TO YOUR STOVE! In most houses, the electric stove is on it's own circuit breaker. If you are in an older home, you're probably lucky you even have a stove...just kidding! If you had your kitchen updated, every electrician should have wired your stove to its own circuit breaker. Shut off the circuit breaker.
2.Remove all the burners and catch plates under them. You are going to lift the top of your stove up. Once you've done that, see what kind of receptacle you have. You'll now have to shop around to find the part. The local appliance store charged us way too much. Lowe's or Home Depot might not have your parts, or they might. Amazon might have your part and if they don't, they will direct you to someone that will. We could have saved half the purchase price if we'd gone there in the first place.
*A quick note* The receptacle is wired to the switches at the front of the stove. They complete the entire circuit, so that is the only thing you need to worry about--from the switch to the receptacle.
After the stove top is lifted, you will find another tray under it. If the wires from the receptacles go under the tray to the "on" switches at the front of
your stove, you'll have to lift this tray up as well. Remove the tray and any other panels you need to in order to get to the switches.
3.Follow the wires, which should be color-coded for that stove top burner, until you find the switch it hooks to. If you have not purchased the parts yet, go ahead and disconnect the wire from the switch and pull the receptacle from it's aluminum cradle. You'll want these parts to take with you to find their replacements.
*note* Your new wire receptacle should consist of the housing for the burner to fit snug into, and two wires that extend from the other end. Electricity works in a circle. If the circle is broken, you have a short and that is where the spark comes from- your electrical current was trying to reach the other side and sparked to get there.
If you do have the parts, compare them to the old ones to make sure they are the same. Nothing worse than spending time on a repair with the wrong parts.
If you have the RIGHT parts, find the correct end of your wires and just slide it over the terminal at the switch. They might be the screw types. Whatever you have, connect it. It does not matter which one went where. As long as you are using the empty wire terminals you just uncovered with the old wires, you are completing the circle.
*Note* I have seen some receptacle kits that do not give you enough wire and require you to splice wires together. Not only is that a bad idea, but does not conform to electrical codes requirements and could result in fire. If the new equipment did not come with long enough wire to reach all the way from receptacle to switch, purchase a longer wire at your local hardware store. For a few pennies more you could be saving your family's lives.
4.Once you have hooked the receptacle ends to the switch harness, tie down the wires alongside the wire bundle until you get to the end.
5.Attach your burner receptacle to the aluminum clamp.
6.Attach your aluminum clamp to the stove top.
7.Screw down all the pieces you removed- anything covering the switches and the bottom tray. Put down your stove top and put in place all the shields and burners. Turn the circuit breaker back on for your stove and try it out!8_10_2012_8_42_55_am.jpg
I have a GE 4 burner self cleaning range. it was installed new. I have lived here since 2006 and was the first and only occupant. The stove is lightly used and kept very clean. I prefer my microwave and...
Are the burners warm all the time? If so then this is a problem. Perhaps when you had your incedent were you leaning forward and pushing on the front controls? Or was the container pushing on controls on the top? .....Pushing on the controls can case them to get hot.
YES, you need a GE professional to look at this.
Good luck,
Shawn
1helpful
A pan stuck to the glass top on the front right burner when the burner was on. When I removed the pan it took a couple of chunks of glass with it. Now there are two chuncks of glass missing from the...
Sorry to read about your problem, I hope this helps you out.
You are not going to like this, and you did not give the model number of your unit. But glass replacement tops, will range from $600.00 to $800.00 just for the glass top. and their is not a way to make repairs, because it is a special glass.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
I have a GE Range model number JBP72DM2BB. The front main burner stopped heating up. Is there a quick fix to this?
I ASSUME THIS IS ELECTRIC. REPLACEMENT BURNERS CAN BE BOUGHT AT MOST MAJOR HARWARE STORES. THEY ARE EASY TO REMOVE AND REPLACE. THEY SIMPLY PULL OUT, LIFT THE BURNER AND PULL TOWARDS THE OUTSIDE OF THE RANGE AND IT SHOULD SLIP RIGHT OUT, THE REPLCEMENT SLIPS RIGHT BACK IN.
I have a Whirlpool Gold Accubake Stove with ceramic top ( approx 9 yrs old) ..the dual burner (one size for smaller pots vice versa) will only heat both burners even when you only turn the smallest part of...
This is becoming a common problem. If your dual burners are controlled by the burner switch only, then you need to replace your dual burner infinite switch. Some models have a seperate rocker switch that switches from small burner to both burners. If you have this style then this is usually your problem. Can also be from shorted wiring but this is very unlikely. Good Luck, Appliance Specialists
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
