MY JENN-AIR #JCD2389GES ICE MAKER STOPPED WORKING AND NOW ONLY GIVES WARM AIR INSIDE WHILE RUNNING Jenn-Air Side by Side first started leaking water on the floor on freezer side, then the refrigerator door was left ajar over night and the refrigerator is not cooling now. the freezer does not keep ice cream frozen.
Hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
water leak from freezer when requesting water from water dispenser
will not keep items frozen in freezer, blows out warm air
