This is the best solution:
It can only be done by changing the base of the logarithm.
The change of base of logB(a) can be found by the division:
logB(a)= [log10(a) / log10(B)]
Note: The change can be to any base but I've simply used base 10 as it's most commonly used.
so it your case you'd find:
log2(a)= [log10(a) / log10(2)].
http://answers.yahoo.com/question/index?qid=20090912063706AA9NOlE
Http://support.casio.com/manualfile.php?rgn=5&cid=004002013
go there its on pdf page 72->?
SOURCE: What is the better calculatorTI-83 Plus or FX-9750GII
If you have to restrict your selection to one or the other the Casio wins "hands tied behind its back". If you need convincing read on.
Advantages of Casio
Newer technology
About half the price
About twice the Ram
Uses iconic menus
Most screens have tab/menus: No need to scroll.
Conic graphic embedded in OS, not need for an extra application
Dynamic graphing embedded in OS, no need for an extra application
Has a reset button
Several types of statistical graphs that do not exit on TI83 (pie chart)
Ability to select the integration algorithm
Better screen resolution.
SOURCE: where is the math button on the casio fx-9750G11
It is a calculator and prqactically every button is a MATH button. It
depends on what MATH you intend to do. Put the calculator in Run/Mat
screen then press the OPTN key. You will see several tabs. Press the
function key under a TAB and explore what is offered. Go through all the
keys (F6 also) and see what the new tabs do.
In general it is most helpful to read the manual that shipped with the calculator.
