It seems 2 probables will cause this problem First probable is your battery, if your Fujifilm battery is not a Li-ion battery it will like this: low power warning for full charged new batteries, good luck else, the problem maybe as turn the power off and on again
You can programme your
remote by below method
Manual code entry
1.Turn
on your television or other electronic component that you want to program
the remote control for.
2.Hold
down the "Code Search" or "Setup" button until the LED
indicator light turns on.
3.Hit
the button for the component that you are programming (TV,DVD VCR, etc.).
The LED light should flicker and stay on.
4.Enter
the 3-digit or 4-digit code that corresponds to the TV or device that you're
operating.The LED light should go off if the code is valid, but will flash if
it is not. Try other codes you have.
5.Try
turning the television or other programmed component off to ensure that the
remote works properly, once the light has gone off.
Auto configuration
1.Turn
on your television or other electronic component that you want to program the
remote control for.
2.Hold
3.Hit
the button for the component that you are programming (TV, DVD, VCR, etc.). The
4.
Press and release the "Power" until the television or other component
turns off while waiting at least 2 seconds between each press.
5.Press
"Enter" or "Save" once the remote has effectively turned
the power off. The LED light will shut off and the remote will now operate the
device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thanx
Manual code entry
1.Turn
2.Hold
3.Hit
4.Enter
5.Try
Auto configuration
1.Turn
remote control for.
2.Hold
3.Hit
4.
5.Press
device.
Thanx
Manual code entry
1.Turn
2.Hold
3.Hit
4.Enter
5.Try
Auto configuration
1.Turn
remote control for.
2.Hold
3.Hit
4.
5.Press
device.
Thank You
