20 Most Recent FUJIFILM FinePix AX200 Digital Camera Questions & Answers
Camera won't stay on. When
It seems 2 probables will cause this problem First probable is your battery, if your Fujifilm battery is not a Li-ion battery it will like this: low power warning for full charged new batteries, good luck else, the problem maybe as turn the power off and on again
11/6/2013 6:40:40 AM • FUJIFILM FinePix... • Answered on Nov 06, 2013
Purple screen when switched on before focusing
Hi Pat, Have this little checked to see if it needs service.
1/26/2013 3:36:16 PM • FUJIFILM FinePix... • Answered on Jan 26, 2013
Purple screen when I turn camera on but focuses after a while. Any way to cure this?
This condition will usually only get worse and requires repair.
1/25/2013 9:33:12 PM • FUJIFILM FinePix... • Answered on Jan 25, 2013
Ax200 usb not recognized
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
3/20/2012 4:32:28 PM • FUJIFILM FinePix... • Answered on Mar 20, 2012
How to use timer on fujilm finepix ax200
i press the down button then left or right to choose a time. hope this helps
2/28/2012 12:15:22 AM • FUJIFILM FinePix... • Answered on Feb 28, 2012
Got new computer, need cd
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
9/11/2011 6:40:15 PM • FUJIFILM FinePix... • Answered on Sep 11, 2011
The usb cable is not connecting to the pc. i have
Having gone over two months without a response to my query, I assume my suggestion to use a card reader eliminated the problem.
8/1/2011 7:12:07 PM • FUJIFILM FinePix... • Answered on Aug 01, 2011
I have a fujifilm finepix
The date and time are stored with every image. Any photo editing program should be able to show you that data (and a LOT more); look for something like "image info" or "EXIF data". If you want the data printed with the picture, refer to the documentation for whatever program you're using to print. Depending on the program and the printer, you may be able to display the date and time on the image, in the margins, or on the back.
5/12/2011 6:28:15 PM • FUJIFILM FinePix... • Answered on May 12, 2011
Need to activate date/time stamp
In playback mode, press DISP/BACK to select a playback display format. This will turn the Information display on, which will show you the date/time the picture was taken.
This camera does not have a Time/Date Stamp that actually stays on the picture like some cameras do. Instead, the Time/Date Stamp is included in the Image File Properties, and can be viewed or modified from any Windows PC. I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
4/15/2011 12:11:05 AM • FUJIFILM FinePix... • Answered on Apr 15, 2011
My computer wont regiser the
Try a new cable or usb port on your computer. Remember to have the camera powered on. Also, try this with the computer off, then turn on with the camera on and plugged in.
3/6/2011 4:50:41 PM • FUJIFILM FinePix... • Answered on Mar 06, 2011
Getting a card read error.
Format the card in the pc ,if dont work replace.
2/15/2011 3:50:06 PM • FUJIFILM FinePix... • Answered on Feb 15, 2011
FUJIFILM FinePix AX200 Digital Camera Logo
38 questions posted
Top FUJIFILM Cameras Experts
ZJ Limited
ZJ Limited
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
View Most Popular
FUJIFILM Cameras
  • FUJIFILM Cameras
Most Popular Question
need owners manual fujifilm s2940wm
  • Cameras
