The Alert Volume is set and can't be changed. The only option is to select the Alert Type as DISPLAY. 1. Press "MENU" button to open menu options. 2. Press "UP" arrow to scroll through menu options until "ALT TYPE" (Alert Type) is displayed, then press "SELECT" button. 3. Press "UP" arrow to scroll through the following (3) alert types: "DISPLAY", "VOICE", or "TONE". 4. Press "SELECT" to choose the Alert Type you want. 5. Press "MENU" to exit menu programming mode. DISPLAY When the DISPLAY alert type is chosen, only a text alert will scroll on the display. There will be no audible alarm. VOICE When the VOICE alert type is chosen, the alert will sound for 8 seconds, then you will hear the voice of the weather broadcast for 5 TONE When the TONE alert type is chosen, the alert tone will sound for 5 minutes, or until you press any button except the "WEATHER/
Choosing an Alert Type:-
SNOOZE" button which toggles to the
Please leave feedback
Cheers
Andy
Press the WEATHER/SNOOZE button to turn on the weather radio. Then press the "UP" or
"DOWN" volume button to select desired listening level. (Note: Turning the volume all the way
down [where no bars show] puts the radio into silent mode.)
Hope that helps resolve the issue.
Regards
Anand
The following instructions are for the T289, which is very similar to the T250. It is possible they will work to turn off your beeps.
Alert Tones
The Alert Tones (beeps) on the Talkabout radios are set at a fixed volume
level and cannot be lowered. However, Alert Tones can be disabled. When
Alert Tones are disabled, the radio will receive messages at the volume
setting you've selected, but you will not hear beeps when you press control
buttons.
Disabling Alert Tones:
1. Hold down the Monitor button while you turn radio on.
2. To re-activate Alert Tones, turn the radio off, then on again while holding
the Monitor button down.
Here is a link to the user guide: http://www.motorola.com/mdirect/manuals/T289_User_Manual.pdf
