Sorry to hear you are having problems with your wii. According to Nintendo, error code 51331 is:
Unable to connect to your wireless network This error code is more specific to having incorrect security settings on your wii. Your encryption key is wrong when trying to connect to your wireless internet. Double check your encryption key with your router's settings and try again.
Error Code: 51331
You can see the official support article from Nintendo here:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51331&system=Wii&locale=lang
SOURCE: nintendo wii console
did u try to input ur wifi numbers and stuff in the settup mode and then try it
SOURCE: Error Code 51331
Wii Error Code 51331 means there is a problem with wireless security.
Make sure your router’s WEP key matches the WEP Key you entered in the Wii.
If your router is using 64-bit encryption, the WEP Key must be 10 characters.
For 128-bit encryption, the WEP Key must be 26 characters.
WEP Keys can only use the characters 0-9 and A-F.
If your router allows more than one WEP key to be entered at a time, make sure the key you’re using is on slot one.
If you double checked the WEP or WPA key with the router and the Wii and they match, but you still receive the Wii Error Code 51331, then MAC filtering may be enabled in the router. You will have to add your Wii’s MAC address to the router’s allowed list. You can do this by logging into your router and going to the “access control, access list, or network filter” settings.
If you still have trouble with Wii Error Code 51331, try changing the wireless router’s channel to 1 or 11. This may increase download speed.
Check Nintendo’s router page for special notes on your router if available. Follow the instructions of the special notes.
Your wireless router must broadcast in mixed or b/g mode and cannot be set to “g” only mode.
If you still encounter the Wii Error Code 51331, try doing manually setting up the Wii’s internet connection. You can find your network information to enter into the Wii by doing this:
On your PC, click “Start” and then “Run.”
Type “CMD” into the field that appears to open a new window.
Type “IPCONFIG/ALL” and press “Enter” to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle the wireless router and modem by unplugging both from the wall. After waiting a minute, plug the modem back in and wait another couple of minutes for the modem to initialize. Plug the router in and wait for the router to initialize. Now try reconnecting the Wii to Nintendo WiFi Connection.
Hope this helps a little
SOURCE: have error code 51331 on wii for netflix will
hi dear you can take help form here and solve this problem yourself
SOURCE: Netflix streaming worked until I connected my
hello... this problem is quite simple to fix... follow this step by step:
Power on your Wii
console and press the A Button on the Wii Remote to reach the Wii main menu.
Use the Wii Remote to select the "Wii" button. Now, select
"Wii Settings" to access the "Wii System Settings" menu. Using the arrow on
the right side of the screen, scroll to page two and select
"Internet." Select
"Connection 1: None" (Don't see
"None" in Connection 1? Click the Connection 1 button, then choose
"Clear Settings.") Click on
"Wireless Connection" and then "Search for an Access
Point." (Are you using a
wired Internet connection to your Wii console? If so, click here for specific
help.) Select
"OK" and the Wii will display all the wireless networks it finds. Select the wireless
network that is yours. (If you're not sure
which is yours, or you don't see any wireless networks, click here.) Asked to enter a
security key? If you are prompted
to "Enter the Password or Key," then the wireless network you are
trying to connect to has wireless security turned on. You will need to type in
your security key or password and select "OK." Don't know your
router's security key? Let us help you find
your router's security key. Select the brand of your router below and we'll
provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple
2Wire All other brands Select
"OK," "Save Settings," and then "Yes." The Wii console will
run a connection test with your wireless network when the test is completed.
You should see the following screen: As long as you see
"The connection test was successful," the "Wii Support
Code" does not matter and can be ignored The connection test
was successful - Then you're almost done! After your connection test, the Wii
console will check if there is a new Wii System Update available. Once you
select "Yes" and "I Accept," the Wii will begin to download
any available updates. Click here to find out what's next! The connection test
was not successful - If the test was not successful, you will receive an error
code. Error Code 51330 or
52130: This means the security code you entered into the Wii is not the same
one your router is set to. Look in your router's settings and try again. Please
refer to step seven (7) above for more information. All other error
codes: Try our error code troubleshooting where we have detailed information on
many common error codes. (You can ignore any "Wii Support Code" you
receive on a connection test.)
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
Hey there. Hope this helps.
51331: this error is caused by the Wii being unable to connect to the access point
So what you need to do:
Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds.
If your router is using WEP encryption
