You can get it from Broderbund direct. If you bought the Boxed version, it is on the barcode label inside on the CD Cover. If you got the online version, the code is in the confirmation email.
Windows 10 hides software it can't work with in a special folder. Go into the Windows 10 system files and see if you can find it that piece of software.
I don't know if Broderbund still operates. The software was generally sold on a disc, not a download.
The Broderbund PDF converter is a piece of software that is apparently bundled with Broderbund's Print Shop. If you upgraded your OS, you may need to update your Print Shop software. If you did a "clean install" or had your XP operating system saved to an Old Windows directory, it is likely that you will have to reinstall Print Shop in its entirety.
In case it helps, here is an article on someone with a similar issue:
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Hello Friend,
This version is not supported by Vista, you have to upgrade it to "The Print Shop® Pro Publisher™ Deluxe 22 " version.
Visit the link below for more details:
