RCA RTD160 System Logo
Posted on Apr 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dvd player won't read DVD, says loading.............. and then it just opens... after a while..
  • 1 more comment
  • Anonymous Apr 23, 2011
    Will it play a CD or does it do the same?
  • Anonymous Dec 14, 2012
    does not work with cd
    it does the same
Anonymous
Level 2:
Guru:
  • Expert 300 Answers
  • Posted on Apr 25, 2011
Anonymous
Expert
Level 2:
Guru:
Answers
300
Questions
0
Helped
52854
Points
940
Please clean the lens of your dvd using cd lens cleaning cd
1helpful
Samsung blu ray player, dvd drawer will not open
Either the loading belt or loading gear wheels have the trouble. Sometimes the disc loading mechanism might need replacement. It won't cost mor for the mechanism. But will feel some difficulty in getting it from open electronic spare part market. it will be best to contact the authorised service center for Samsung to get it repaired.
Door won't open to insert dvd
The gears are jammed, the timing gear is out of sync, or a broken loading belt, or cogwheel.
Won't spin
Hello
The loading mechanism to your player is faulty. It doesn't engages the disc in to place perfectly. Replace the loading mechanism.
Samsung dvd-v4600 disk drawer won't open
Can be that the drive belt of the loading mechanism has broke,take it to a technician to open unit
I have a JVC VCR/DVD-recorder, model DR-MV7S. It developed a problem... when you placed a DVD on the tray & pressed the "eject/open" button to take the DVD into the recorder, the tray...
This can be due to a faulty LOADING drive settings, It can be due to a misalignment of the loading section and so the load does not reset to the PARK CONDITION of the MODE.
It can be a aulty gear, belt or jamming in the drive.
You need to open the player, remove the mechanism and manually check the forward and loading motion which can confirm. If the belt or the drive is jammed this can be checked and replaced or reset.
Check the mode switch settings of the forward loading.
Have a philips pet800 portable dvd player which won,t read dvd discs.the display shows the dvd loading then after a minute it stops and displays that there is no disc
The problem is the lens of your dvd. You will see the optical lens when you open the the dvd and put the disc. Cleaning the lens of the dvd, you must be very careful, never touch the lens with your hand,Use a cotton buds to wipe the the lens gently.
2answers
Samsung dvd player does not read dvd disc.it reads "no disc".
I also have a Samsung Dvd player. If it is a dvd you burned yourself it may not recognize the disc. If you have loaded a purchased or rented disc and it still won't load, I would say the head is dirty or the unit is defective. I would try a head cleaner first.available at most electronics stores If that doesn't work you probably will need to send it in for repair.
good luck
Loaded dvd and now it won't play and it won't open/close
Hi i have had a similar problem to this before. I never could get it open without force, but if it is only the disc you are after then i would recommend forcefully removing the disc with a knife opening the dvd slot or by unplugging everything and unscrewing the dvd player altogether there might be something lodged in the dvd player preventing it from reading or opening. Be sure to press the power button when you unplug as it may contain electricity still.
2answers
Sanyo dvw 6000 dvd/vcr player
DVD loading mechanism doesn't load completely that's why opens after attempt of loading.
You need to open top cover of unit and inspect loading belt might be lose, tray timing can be out of phase, some wire got stuck with tray while loading etc.
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
