Televison & Video Logo
Posted on Apr 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
You said that there is a video fuse on a sanyo lcd model # dp42647 the power supply is turning on have my 24 volt ane the trun on voltage of 3.1 volt on the inverter have sound no pix lid do not light up
Anonymous
Level 3:
Master:
  • Master 691 Answers
  • Posted on Apr 21, 2011
Anonymous
Master
Level 3:
Master:
Answers
691
Questions
Helped
126673
Points
1740
On the inverter board you should have the12- 24v going to transformers
Sanyo dp42647 pwr light but no video or audio
Cable or possibly the source it's connected to.
1helpful
Sanyo DP42647 tv won't turn on.
sanyo LCD tvs recieve the on command from the main board so chances are the main board was also damaged
Sanyo model 42848
This could be a faulty back light lamp.It is located right at the back of the screen It is an cold cathode lamp supplied by a high voltage from inverter board .Inverter board has a input voltage of 24 volts inverted into 300 volts AC this lamp lights up the screen...
You need to open the back cover to check the lamp.....
1helpful
My sanyo vizon dp42647 wont turn on
Some food for thought here the power supply and part of the set:
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
If the set is opened look on the power supply board for caps puffed up like these--dead giveaway.
If you have questions feel free to comment here--I am not the number one rated expert here for the last six weeks for nothing and I do this here for free.
SD TECH
2helpful
Tv click it but no picture no sound power supply voltages are ok no out voltages on high voltage board
Try to remove the connector that supply the high voltage and observe if the unit will produce a sound. May be the inverter is faulty. Or try to check if there is a 24 volt dc supply to the inverter or the high voltage board.
Sanyo lcd tv blinking
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
5helpful
Screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
2answers
Sanyo dp42647 wont turn on
Online Sales Service (English only):
3333 SANYO Road
Forrest City, Arkansas 72335
E-mail: [email protected]
Phone: (800) 877-5036 Ext. 1512
Fax: (870) 633-8839
7:30 am - 4:00 pm
CST Mon-Fri
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
