Posted on Apr 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Audio will not play - Audio Players & Recorders
Anonymous
Level 3:
  • Master 32,281 Answers
  • Posted on Apr 20, 2011
Anonymous
Master
Level 3:
Answers
32281
Questions
Helped
7913524
Points
102259
MP3 players can only play music files in mp3 file format.You need to convert your CDs to mp3 music files onto your computer ordownload them from the Internet and then copy them to your MP3 player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
2answers
We have a Wurlitzer rave on juke box that will not play the audio on a video CD. will pick up, place and spin, but no audio. Plays ordinary audio cd's ok, just not those with a video.
Is this Wurlitzer designed with a screen to play videos? Has it played video CD audio in the past?
There are a lot of different audio/video file types and some CD setups will only play 'audio' file types, (MP3, AAC, M4A). If the file format is commonly used as video the electronics in the player won't recognise the format and won't play it.
Why does my receiver start stop producing audio output half an hour after turning it on?
Most likely is an intermittent solder connection opening up as set warms up.
May 09, 2012 • B&K CT600
Dear sir, i have compaq presario cq40-330tu laptop.i want to play audio in my laptop by using windows xp
...please check your audio driver of your computer if install already or check your audio player if this player can play the audio format that u played...if not install, try to install first before you can play an audio files...or install a audio player that can play the audio format that you have...
7helpful
2answers
Video is not playing with audio
the bit rate of audio is high thats why audio not support while playing video, use normal bit rate video or audio , u can convert your fav video and audio through your pc
14helpful
Ulead audio playing problem
By haneef_a on Aug 04, 2009
I can't play my project. I get this message:
Failed to use Direct Show video engine. Can not play back the audio stream: no audio
hardware is available' or the hardware is not responding. (13102:2:4)
3answers
DTS via OPT2
no descodifica dts a traves de opt2 solo de su dvd opt1
How to play audio clip in java
  • Create an AudioClip object
  • Load .au sound file into AudioClip
  • Play sounds once or loop continuously
  • Stop playback
Here's how the code for these steps looks:
import java.applet.*;
AudioClip ac = getAudioClip(getCodeBase(), soundFile);
ac.play(); //play once
ac.stop(); //stop playing
ac.loop(); //play continuously
It would seem logical to use this same code to play audio clips in a Java application. Unfortunately, if you do that you will get errors from the compiler. Why? Because the AudioClip object and the getAudioClip() method are part of the java.applet package -- and are not part of applications. The good news is we can dive down and make things work ourselves.
The trick to solving this problem is to use some undocumented features that are provided by Sun in its JDK. Taking a peek inside the classes.zip file from the Sun JDK (using any of the various zipfile utilities), we find not only the standard Java packages such as java.applet but also sun.audio. (These are in the directory sun/audio.)
The sun.audio package contains everything we need to be able to play audio clips! Here's the code:
import sun.audio.*; //import the sun.audio package
import java.io.*;
//** add this into your application code as appropriate
// Open an input stream to the audio file.
InputStream in = new FileInputStream(Filename);
// Create an AudioStream object from the input stream.
AudioStream as = new AudioStream(in);
// Use the static class member "player" from class AudioPlayer to play
// clip.
AudioPlayer.player.start(as);
// Similarly, to stop the audio.
AudioPlayer.player.stop(as);
To use a URL as the audio stream source, substitute the following for the input stream and audio stream setup:
AudioStream as = new AudioStream (url.openStream());
Playing the audio stream continuously adds a bit more complexity:
// Create audio stream as discussed previously.
// Create AudioData source.
AudioData data = as.getData();
// Create ContinuousAudioDataStream.
ContinuousAudioDataStream cas = new ContinuousAudioDataStream (data);
// Play audio.
AudioPlayer.player.play (cas);
AudioPlayer.player.stop (cas);
4answers
Dts audio cd
kindly check digital settings on your dvdplayer. The output should be in digital domain. Are u using original dts audiocd or burn dts audiocd.
Coby mp-833
If your adding music to the device and its not playing, its because your audio files are not the correct format. This unit only plays MP3 audio or Uncopyrighted Windows Media Audio files. You can test this by connecting the MP3 player, copy one of the sampe audio files under 'My Music' location on your computer and paste it on your mp3 player. It will play the audio fine.
How to play: Hold in play button until red ligh is steady, then press Play again to start the audio.
Make sure you remove any audio file that is not the correct format.
to check format of song:
right click the song, go to properties, under properties it will say 'Type of File', make sure this says MP3, thats the safest way to go.
2answers
Problem playing a downloaded audio book
Perhaps your audio book was from audible.com. They use their own audible format ( .aa instead of .mp3) and only certain mp3 players can play .aa files. If the book is in .aa format, go to www.audible.com and check to see whether or not your player is compatible with .aa files. If not, you're outta luck. durok
 Grubhead
Grubhead
SmartAviator
SmartAviator
