Jilbere De Paris Jilbere Titanium Tools Excel Flat Iron Logo
Posted on Apr 17, 2011
Hello, Jilbere Titanium Tools hair straightener is not operating correctly. When plugged in and turned on, the red light indicating that the straightener is on lights up, however the plates do not heat up. I've had the straightener for 6 months. Thanks, Nicole
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 28, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
366
Points
Well my flat iron dosnt have that pronlem but in the middle of the plates it has a gap in it .....did yours have a gap in the middle of the plates??
Can a jilbere curling iron be fixed
If you know anything about electronics you could probably fix it. Those kinds of devices have a fusable link in series with the heater and when they exceed their rated temperature then open up to keep things from starting a fire. Typically you can purchase them at a place like Radio Shack if you can determine the temperature and current rating. Good luck.
BABNT2091T
The Problem with BaByliss PRO Nano Titanium 1" Ultra Thin Hair Straightening/Flat Iron can be resolved if you call the company support line or web page.
3answers
What types of hair irons are there?
The main types of hair irons are;
Curling irons - they create a curl or wave in the hair
Straightening irons - flatten or straighten the hair
Crimping irons - create a look similar to crimps left after braids are removed.
I recommend to get a better hair straightener, I bought mine at safrons it's the Karmin G3 Salon Pro with ceramic tourmaline plates to avoid hair damages, it heats up really quick and leave my hair soft, shiny and super straight, hope this helps.
5answers
How do you use a conair straightener? what does the dial with the numbers mean?
The settings 1-10 are for wet and easy-to straighten hair. Like hair that is a little thinner or almost straight.
The settings 11-17 are for damp hair that is about average thickness.
The settings 18-23 are for hair that is thick or wavy.
Lastly, the settings 24-30 are for dry hair that is harder to straighten.
So, the higher up you go, the higher the difficulty the hair is.
Hope this helps! :]
1helpful
4answers
I need directions on how to use the Revlon ceramic Straightener model RVST2024
I love my hair straightener. It doubles for a clean modern straight look to sexy voluptuousness Kim Kardashian curls without going to the salon. If you do it right your hair will look professional and feel so soft.
1. Clean and Wash Hair: I always like to have clean hair before I style it, it isn't necessary but it makes me feel more refreshed.
2. Make sure your hair is dry. I prefer to air dry because it is the healthiest way to not damage your hair. But if you want to get more volume, using the blow dryer works well.
3. Before using any straightener make sure you get heat protector gel or spray because this will help make sure your hair does not become damaged when styling.
4. I like to split my hair up into sections to get them out of the way by using hair ties or hair clips. Sectioning your hair also helps a lot of if you have specific styles you are going for.
5. Finally, do not turn on the straightener too high because it's a sure way to damage your hair. Instead, consider low-med. If it's your first time, don't rush it because you will get burned. Give yourself an hour or more! Learning how to do it the first time can be frustrating and it doesn't always look great the first time. With some practice you can also create curls with a straightener as well.
Other tips: They have specific wet-dry straightener which can be used on wet hair but unless you have those, do not use the straightener with your wet hair because it'll give you split ends and damage your hair.
Here are some more tips for straightening that might be useful for you.
Hair Dryer cord has electrical shortage
IF you take off about a inch of wire from the plug and re-wire it [somtimes with new plug also] make sure to remember the fuse and this should do the trick.
Broken hair straighteners
my hair straighteners are meant to heat up to 230' but i am lucky to get them to heat up at 160 and stay on ? please help
Top Jilbere De Paris Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Jilbere De Paris Health and Beauty Expert? Answer questions, earn points and help others
