SOURCE: Neovo F-417 failure
When troubleshooting another problem with this monitor i had it open and noticed that all thought this monitor has a "fixed video cord" once the unit is opened up it actually plugs in just like any normal video cable for a monitor. If the monitor video cable is the problem(bent pins, twisted to much, left kinked) then replacing it is an option. Simply open the monitor carefully(so as not to break any clips) and remove the EMI Shield. Once you do this you will be able to see where the video cable plugs into the monitor and replace it.
SOURCE: I HAVE A NEOVO E-19A MONITOR. ON BOOT UP SCREEN
http://www.devicemanuals.com/guide/LCD/AG%20Neovo/AG-Neovo-S-19A-LCD-Display-English-Owner's-Manual-T1RjMU9Uaz.html
dlc.sun.com/pdf/820-0119-10/820-0119-10.pdf
http://www.scribd.com/doc/3082274/AOC-LCD-Monitor-786LS-Service-Manual
Use these training manuals, to troubleshoot and sort your issue out.
Above is a user manual, and a service manual, in the service manual, are the troubleshooting steps to perform to isolate the problem, and hopefully repair.
SOURCE: F-17 neovo monitor stopped working. power light is flashing yellow
The power supplies in inexpensive monitors frequently blow capacitors, and during a certain period in the 2000's there was a capacitor blight due to a stolen formula for water-based dielectric compound that was flawed. Millions of electronic devices manufactured during that time proved defective due to bad capacitors. If you've never repaired a monitor it would probably take you a total of ten hours to do a capacitor replacement. You can usually tell by visual inspection if a electrolytic (can) capacitor is bad. The tops are made to bulge. I usually just replace all the large ones. The tiny ones are usually unaffected. There are other problems that cause the yellow light, but if you're ambitious, just take a look inside. There are three things inside a flat-panel monitor--the display, the display controller, and the power supply. The AC cord plugs into the power supply and into your wall outlet.
