20 Most Recent
Neovo E-19A 19" LCD Monitor Questions & Answers
Screen goes black in half a second....
Call the service dept. in the above post. Tell them the model and serial number of your monitor and order a backlight inverter board(approx. $35 plus shipping). Open up the monitor and plug it in, should fix the problem. This problem could also be caused by one or more backlights(small flourescent tubes) being bad. I just fixed a Neovo F-417 display by replacing one of the backlight assemblys. I also just fixed a Neovo E-17DA monitor by replacing the inverter board.
I got this monitor off
Check the VGA output pins on your computer. Install a different monitor and see if it works on your computer. Or it could also be the VGA cable (pins) on the monitor is loose.
Monitor buttons don't work
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
AG Neovo Monitor not working
nothing you can reset from monitor other than color brightness. You can contact with AG Neovo as
[email protected] to have a RMA number and they will estimate you the repair fee if it is out of warranty.
Green light is blinkering
Hi.
The green light is blinking because a fault had been detected. This may had been caused by a power surge, or by a contact in the video connection cable.
Try first disconnecting power cord for ten minutes, and check video cable and connector on both monitor side and computer side.
If possible also test the monitor using a different computer, a faulty video card can send the monitor in fault mode.
If that does not work, then all you can do is contacting the manufacturer. In that case the blinking light means that there is a fault, and that the unit must be taken apart and tested at component level to find the fault.
Here the contact form.Here the phone support number (USA only).Here an article on the same topic:
Monitor led is blinking but the unit does not start up.Regards.
No display
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Cause of power going
off: There is a bad 1000uF, 16V cap
on the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35V
cap for $2. This will work.
Why did the cap go
bad? The cap is too close to a heat
sink and over heated.
What does this cap
do? This cap sends a signal to an IC
which keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage is
applied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor:
These monitors are difficult to open.
The two plastic pieces snap together and must be pried apart
with a flat screw driver.
After removing the stand, you need to insert a flat screw
driver at the bottom of the screen where two slots are located. Then work the screw
driver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuit
board.
Unplug the monitor cords from the driver board and remove
the screen.
Unscrew the mounting screws from the power supply board and
remove.
You will need to pinch the plastic support in the middle of
the board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will be
on the side of the cap. It will be bulged up on the top. You will see burn
marks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + of
the cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from the
heat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
