I have an Olympus micro 5010 Digital Camera and when I plug it into the usb port my XP (SP3) Laptop recognises it as a u-5010 but loads it as an unknown Digital Still Camera
When I plug it into an older XP (SP3) laptop I have there isn't a problem
Jim
Have you considered NOT connecting your camera to your computer? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.Have you considered NOT connecting your camera to your computer? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
You can't post conmments that contain an email address.
1. You might be able to download foto's from the camera, when you do it manually from within the installed Olympus program. Windows XP has problems with auto downloading foto's from ib. 2. Otherwise, check if the computer is recognizing the camera (see LCD) and with the Explorer if a removeable memory device is available from the camera. 3. Try putting the camera into another USB port, or try the camera on another computer. 4. As an alternative, you might want to install a better and also free Olympus program: http://support.olympus-imaging.com/ov2download/index/?Lang=ENU
It should populate into the window that launches when you plug in your camera. If it doesn't, launch Picasa and then plug in your camera. Either way, Picasa will go immediately to importing photos and you can pick which ones you want to transfer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
I've seen this on some users, did you try a different USB port?
does anything happen when you plug the camera in when it's on? a beep? a window pop up?
The C3000(which I have) and C3030 are not directly supported by any version of Windows. You must either use the Camedia software to access the camera(via USB connection) or use an external Smartmedia card reader like a ZIO(I have one, it works great). Camedia 2.0 will work(with XP) but it will not allow you to select more than one picture at a time to download from the camera. I have heard that Camedia 2.5 fixes this problem with XP and it is available for purchase from the Olympus website. I decided to get the card reader instead of the new version of Camedia because I use Photoshop to do my editing. I believe only the latest Oly cameras(like the 3020) have direct support under XP. By this I mean when you connect the camera to the PC it shows up as a new drive letter. Hope this helps.
