This can be due to the fact that the heaters draw up more current than required and so trips the circuit. it will be important to remove and check the heaters, check if the contactors are faulty that feed supply to the heaters. Also if the trip is a ELCB- then with some leak in the circuit , motor, heaters, the circuit will trip. Hence check the electrical, check the ground on your dishwasher. Use an external ground and check
