How do I fax multiple pages? It wants to fax one at a time.
SOURCE: Faxing multiple pages
Faxing using the scanner glass, it would ONLY allow you to do it one at a time. You can Use the Automatic DOcument Feeder on the TOP part of your printer. load all those pages and try to do the faxing. That should work.
Please, let me know if the issue is resolve.
Thank you so much.
adonscott
SOURCE: multiple page faxing
press fax then press faxtel nummer . put page 1 on the glass press start mono (b/w mono) You will be asked if there are another pages. Press 1 and put the next page onto the glass. When finished press 2 (No, no more pages). machine will start calling and sending.
BTW Did you read the handbook? This is explained within the handbook which can be downloded from the brother homepage of your country!
SOURCE: faxing multiple pages
reinstall the printer software. deleted the existing printer software first.
SOURCE: Document feeder pulls in multiple pages
Try FANNING the paper before loading into tray. The air in between each sheet should help.
You may find more help here...
HTML clipboard
HTML clipboardHow
to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP,
Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros
Magic Inkjet Flush Kits (Ebay)
