NorStar Jazz Plus 4400 Corded Phone Logo
Anonymous Posted on Apr 11, 2011
I have a Jazz 4400. I want to enter numbers in the first four buttons, but leave the rest of the buttons blank. I also want to take out 911, as we have special needs child and would like it taken out, thank you bernice McEwen
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jul 30, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
585
Points
10
To progran a number
"Save" "Phone number" "Save" "Line position"
To remove a phone number
"Save" "Redial" "Save" "Line position"
  • Anonymous Jul 30, 2011
    To program a number:
    To leave blank a line button
    "Save" "Redial" "Save" "Line position button"
Where can I find operating instructions for a Jazz 4400 telephone. I want to change the speed dialing to 10 digit but can't find the original instructions.
Jazz 4400- Programming an Autodial key: 1) Lift handset wait for dial tone 2) Press SAVE key 3) Dial the number you wish to save 4) Press SAVE key again 5) Press the Autodial key that you want to save number to. // Notes: The number can be up to 16 digits. If you need to add a pause (for PBX system) press REDIAL key. //
Jazz 4400 has 10 Autodial keys each can store 2 numbers for a total of 20 saved numbers. Press SHIFT key before Autodial key to access second number. Their is a HOTLINE key to store one frequent or emergency number programmed same as Autodial.
1helpful
How to hard reset C855 Jazz Ultratab
plug is broken off where can I send it for repairs unit is like new
Deleting contacts from phone
How can I delete stored phone numbers, or changed the saved phone numbers on Nortel Jazz 4400?
1helpful
3answers
How do i reprogram my speeddial numbers on jazz 4400?
Although I've been unable to locate a User Manual specific to your phone, the following information pertains to programming most all NorStar phones:
To Program Buttons On Your Phone:
For External Numbers:
1. Press the Feature button, then * 1
2. Push the button you want to program
3. Display will read "Program and OK"
4. Enter the telephone number, then press the OK softkeyFor Internal Numbers (Extensions.:
1. Press the Feature button, then * 2
3. Display will read "Intercom #:__"
4. Enter the extension number
For Feature Codes:
1. Press the Feature button, then * 3
3. Press the Feature button then enter the Feature Code
To Change the Contrast of the Display:
1. Dial the Feature button, then * 7
2. Press the number keys 1 - 9 to your desired brightness level
3. Press the OK softkey
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 - 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.)
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94. that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
Additional information about NorStar phones can be found by clicking here:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
2answers
2007 vw jetta radio code please!!!
Send the request via email through this site these guys can help or go back to dealer and get them to get it for you.
http://autoforum.classifieds1000.com/Volkswagen-Quantum/2007_VW_golf_radio_code
Below is procedure once you have the code:
* Turn on radio -- the word "SAFE" will be displayed.
* First press the MODE button and then press the SCAN button and hold them down simultaneously until "1000" appears in the frequency display. Release the buttons. Do not, under any circumstance, continue holding the buttons down or press them once again. This would cause the radio to take the number "1000" as the code number.
* Using the first four radio station buttons, enter the code number found on your Radio Card. Use button 1 to set the first digit of the four digit code, button 2 to set the second digit, etc. The first digit of a four digit code must be "1". If your code number has three digits, the first digit on display must be set blank.
* Once the code is shown on the display, press and hold the MODE button and SCAN button simultaneously until the word "SAFE" appears in the frequency display. Release the buttons. A radio station frequency will automatically be displayed. The radio will now play once again.
If, when cancelling the electronic lock-up, a wrong code number is entered by mistake, the word "SAFE" will appear in the frequency display first blinking, and then continuous.
You can now repeat the entire cancelling procedure but only once. The number of attempts will be shown in display.
If the wrong code number should be entered again, your radio will be locked up for approximately one hour. The radio will not play. Leave the radio switched on. After an hour, you can cancel the electronic lock-up as previously described.
This cycle, two attemps - one hour lock-up continues again. //
5helpful
How do I change a number on speed dial?
Locked and only number i can call is 911
hello,
what you need to do from your phone is that click on menu button then click on zero four times i mean ,
this way MENU 0000 then you phone will then come up again.
Good luck and thanks for using fixya.
1helpful
Radio wont display "code"
you may have entered the wrong code or not pressed "enter"button after using code.leave to rest overnight then try as it may be in failsafe mode.
Blank screen acer 4400
remove battery, press and hold power button for 5 seconds, then put battery back in and start.
This usually works. If by slight chance it does not, check that the memory cards aren't loose or faulty.
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
