thx so much, i was without a car 4 2yrs and reset 4 oil change was located with tach, speedometer,etc this tiny info i could not find in my manual under oil changethx so much, i was without a car 4 2yrs and reset 4 oil change was located with tach, speedometer,etc this tiny info i could not find in my manual under oil change
You can't post conmments that contain an email address.
To clear "TIME FOR SERVICE" from the Saab Information Display, press and hold the "CLEAR" button for at least 8 seconds. A signal will be heard indicating reset. After the 21st restart of the vehicle, the "TIME FOR SERVICE" message will be cancelled.
So what is the question? You know what happened If you don't believe them,go into the service bay & see for yourself & have them prove things to you How they found that out,it's your car
If you have a code scanner you can do it yourself. Auto zone and Advance will not reset your codes anymore. You have to find someone that has a code reader and reset it. Maybe your local shop will do it for you?
The window motor is working too hard go to Napa and ask for the silicon lube made for windows and lube up the window rims and guides this should allow the motor to work less hard.
If you lower the back seat you will see a plastic cover on the botom of the opening. Remove the cover (6 appolstry fasteners) to reveal a metal box. The box is not actually a box but a cover for the hydrolic pump. Remove the fscrews from the lid and lift. The resevouar is clear and easy to check against the two fill lines on the side.
Hi,If you press and hold the reset button on the SID unit the message will go out ,however it might come back on a few times so you may have to repeat this for a couple of days till it stays out.
