Not every USB to Ethernet adapter works for the Wii. Here's what I've found from Nintendo's site. You may need to connect with your Wi-Fi and update it first.
Error Code: 51420
The Wii console is not able to connect to your wired router or modem.
1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
2. Select "Wii Settings".
3. Click the left arrow to get to Wii System Settings 3
4. Choose "Wii System Update"
5. Choose "Yes" to connect to the internet and perform a Wii system update.
2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
