Sounds like an air lock is making the water fill in squeeze thru the piping. C if u can undo the piping from the tap below the tank and take out tank and try flushing the unit thru from the out side fill pipe. U may hv something stuck in the pipe line. cheers
There is a rubber seal at the bottom of the flush valve that covers the openning at the bottom of the tank. If this rubber seal has perished slightly then it will leak water into the toilet bowl. This rubber seal need to be replaced to form a proper seal to prevent water leak.
The following Zip codes depends in the Area of Manila
1000: Manila Central Post Office
1001: Quiapo
1002: Intramuros 1003: Santa Cruz South
1004: Malate
1005: San Miguel
1006: Binondo
1007: Paco
1008: Sampaloc East
1009: Santa Ana
1010: San Nicolas
1011: Pandacan
1012: Tondo South
1013: Tondo North
1014: Not used
1015: Sampaloc West
1016: Santa Mesa
1017: San Andres
1018: Port Area South
Please comeback and rate my answer. Thank you for asking Fixya
I would say yes....here is the .pdf for your toilet and it has nothing like that in it...your toilet should be a simple fill device and flush mechanisim...
I would return it for a new one...
Tighten the nut a quarter turn. If that doesn't do it then shut off the water supply. Unscrew the nut and get you a new rubber washer to replace the old one. If that doesn't do it, then go to the blue or orange box store and get you a new 12" stainless steel flex line for toilets. Bring your old supply line in to correctly match up the size so you don't have to make 2 trips if you buy the wrong one.
