SOURCE: Panasonic KX-T7731 headset mode? Could someone
It's automatic. Press the SP Phone button.
My headset is a TCA-60 and it works in all systems on all Panasonic phones.
Carl
Testimonial: "thanks for the help!"
SOURCE: How to program so when someone is on a line, their
You have 24 buttons that can be anything. The key is PROGRAM press the button and dial 1 + the extension and STORE or SAVE. The "1" tells it to be an extension. You press PROGRAM on an idle phone.
Carl
SOURCE: How do we keep our
This has about 5 different conditions, so let me start somewhere.
Pretending your 7731 is connected to a recent Panasonic KSU, like a TA series, you have the ability to set the time by hand, or CID delivered in the first call after 2 or 3 AM will do it. If the sender is still on standard time (typical with VoIP delivered CID), then it will reset the clock to a different time (-1 hour) every day and it will be noticed if you set the clock and the first call of the day follows.
In addition, via programming from the main phone, you can set manual or automatic switching for day, night, and lunch modes. That procedure is outlined in the Programming Manual for your system, but it involves setting the clock times in Maintenance console 1.4 or programs 006 and 007.
If you absolutely want to never have to deal with clocks or night mode, then set 006 to manual and dial 781# on the intercom from the main phone (x101).
Note that this is only the solution for TA series KSU's.
