Sony Ericsson W910i Cellular Phone Logo
Anonymous Posted on Mar 16, 2011
My sony w910i has been blackout for almost 1 month n since then it continues to on/off, screen blackout when it receives an incoming call + messages n next, the screen went like it has been crashed or something like that.. could u help me?? thx.. regards, Ms. W910i^^
Najwa Ahmad
Level 3:
Master:
  • Sony Ericsson Master 386 Answers
  • Posted on Aug 30, 2016
Najwa Ahmad
Level 3:
Master:
Answers
386
Questions
Helped
352420
Points
1976
LEO Privacy makes my phone fly. My phone always hang, because there are always some apps run in the background. One day I suddenly find in LEO Privacy there is a Boost, and then I always use it, and now my phone runs faster,LIKE it!https://goo.gl/rl0dX8
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
242
Points
My sony w910i has been blackout for almost 1 month n since then it continues to on/off, screen blackout when it receives an incoming call + messages n next, the screen went like it has been crashed or something like that.. i just want to save contact numbers. how can i do that?
  • cherry_angel Apr 11, 2011
    THAT WAS THE THING HAPPEN TO MY PHONE...I CANNOT USE IT ANY LONGER
    SO SAD....
Burgert Potgieter
Level 2:
New Friend:
  • Expert 112 Answers
  • Posted on Mar 16, 2011
Burgert Potgieter
Expert
Level 2:
New Friend:
Answers
112
Questions
Helped
14995
Points
310
You have dry connections in the phone,maybe caused by water or moist.Only solution is the repair shop.
Need unlock code for sony ericcson w910i
http://ccm.net/faq/sony-ericsson-507#29341
How to unlock a Sony Ericsson W910?
Issue I have received my codes NCK and NSCK from my mobile operator, how to use them and unlock my Sony Ericsson W910?
Solution
  • How to enter the Unlock Code on an Ericsson.
  • Turn on your Phone without SIM card.
  • Press the left arrow key (1 time), then the * key (2 times) and a last press on the left arrow key.
  • You see the message: "Personalized with MNC2."
  • Now enter the unlock code you received from your mobile operator.
4helpful
Screen blackout but still functioning..
The problem is with the display or the strip, U need to change the display check if its working if it does not change the strip. Usually slide phone frequently get strip problem. Try with the strip.
Regards, Kesav
3helpful
2answers
I want to unlock my sony ericsson w910i fre how
hi friend,
press * and then press the right soft button to unlock if it doesn't works check this out Unlocking your Sony ERICSSON W910i is just the start of roaming freedom. This safe, simple process is one of the easiest ways you'll ever find to save money. The unlocking code and five minutes of your time will enable you to use your handset in ways you never thought possible.
We need only a short time (no more than 12 - 24 hours ) to generate your Sony ERICSSON W910i subsidy code. The sooner you place your order, the quicker you'll receive the unlocking code and be on your way. Both ordering and entering the code are easy. Just follow the instructions.
How It Works
  1. Select your phone and fill out our order form
  2. We will email your unlock code along with easy to understand instructions on how to enter it.
  3. Put in a different SIM card and enjoy your new freedom.
Once you have received your Sony ERICSSON W910i unlocking code, it is very simple to enter it:
  1. Remove the SIM card. Turn your handset ON
  2. PRESS the left arrow ONE TIME
  3. PRESS the * button TWO TIMES
  4. PRESS the left arrow ONE TIME
  5. The message "Personalize with MNC2" will appear
  6. You may now enter the Unlocking Code we sent to you. It may be necessary to PRESS ENTER or OK
    ERICSSON
    -W910i-,K850i-&-W890i-UNLOCK_...%20-">cgi.ebay.co.uk/UNLOCKING-FOR-SONY-ERICSSON-W910i-,K850i-&-W890i-UNLOCK_... -
hope this helps u
thank u for using fixya
please rate me............................
regards
sivaranjini
6helpful
Sony ericsson w910i blank screen
this because of the strip inside the mobile...i think that got damaged in u r mobile...so u just give u r mobile to u r sony service sation and they will take care of u r mobile....and then u r mobile will be proper...be cool!!!!
4helpful
Sony Ericssion w910i hangs when ever i receive any call
1.backup first all of your contacts and important files
2.make a master clear w/ your phone and after restart.
3.if still the same make a fullflash or upgrade your firmware.
1helpful
Operation failed
Have you tried a master reset >?
Menu > Tools > General > Master Reset
My Sony Ericsson W910i hangs and restarts!!
hanging problem is due to torjn
just format the phone and it will be ok
sagar
4helpful
Can not connect sony W910i in 'phone mode' via USB cable
Please check if the OEM is installed properly, You would get a Blue screen error only when your computer RAM has some problems and if the Drivers are corrupted for the used application. So i would suggest you to reinstall this Sony ericsson PC suite.
1helpful
2answers
Compatibility issue: Sony BDPS350 Blue-ray & Yamaha RX-V1700?
HDMI compatibility issues continue to plague the industry and this more than likely is the problem. There are a couple of ways around this.Some people insist on "hot rodding" the dvd and tv by hooking up directly to each other avoiding the receiver all togeether (I do this).But you lose functionality and it makes things more complicated for other family members. Your best bet is to use RGB and Digital audio cables.You won't notice any quality loss and there is a possibility it will look better.
2helpful
2answers
Sony ericsson w910i :problem with send/receive sms
you don't have to do the complete master reset..this happened to me yesterday and i did 'reset settings'. it works as well and you dont have to move any of your files. :)
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
