Efficient Networks SpeedStream 5100 Modem Logo
Posted on Mar 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lost power adapter to my speedstream 5100 ethernet ADSL modem. need specs cuz i have a big box of adapters and i dont know which one it is?
Joseph Midjette Sr.
Level 2:
Scholar:
  • Expert 158 Answers
  • Posted on Mar 12, 2011
Joseph Midjette Sr.
Expert
Level 2:
Scholar:
Answers
158
Questions
Helped
51751
Points
449
Lost box and directions on how to set up this printer. Need to find TCIP IP address of this printer to connect wirelessly with laptop
it does not have ethernet adapter according to the specs no no ip address or interface ?.
Do you have the optional bluetooth adapter with the printer. ?
You may be able to connect via bluetooth
http://classroom.synonym.com/make-kodak-printer-wireless-bluetooth-17749.html
http://support.en.kodak.com/app/answers/detail/a_id/1157/selected/true
http://www.amazon.com/Kodak-Wireless-Adapter-Printer-Dock/product-reviews/B0006NMSK6
Power requirements for an Efficient Networks SpeedStream 5360 Ethernet ADSL Modem. I need to get a replacement Power Supply.
You need a power supply which converts AC to 12Volt DC power.
While purchasing Please keep in Mind that the ADSL power IN socket should be matching with the new Power adapter.
HOW CAN I GET MODEM ACCESS CODE ON SPEEDSTREAM 5100
hello
When you have modem plugged straight into computer, you can access it at 192.168.0.1, should ask for modem access code, (on bottom), then you can click 'advanced' > ppp location and set it for 'on computer'. There may also be a link for technician stats, it will give you info about isp connection. You should / might be able to browse but ISP may need original MAC address of machine (network adapter} you used when 1st signing up. Or if set to PPOE, it would look for name / PW in order to access INternet through ISP.
Anyway, try (after setting PPP on computer) Modem into WAN of router, access router, set PPOE > insert Log-in name / PW and save all settings. Then try homepage, if no, have router "clone MAC address" of the Network adapter you had the 5100 plugged into. Now it should work, even if no <INTERNET> light. ETHERNET light should be constant. Have router use DHCP to address machine independantly of what ISP addresses router, which it will do when modem (having connection confirmed with DSL light)
The other way, PPP location set 'on Modem', means the modem signs into ISP and then it assigns IP address with a timeout around 20 minutes. By getting connection test results when modem is connected to computer, it may seem to make sense, by understanding how ISP knows that modem access code / MAC address, and lets the settings of modem determine if router needs to sign in or not. If PPP is 'on modem', it will be looking for the MAC address of computer, that is why you may need to clone that address into router, so the router can appear as the machine to the modem, than the router assigns net address to computer.
Regards
3helpful
Speedstream 5100
red light on DSL implies no ADSL communication to ISP. Check your phone line connection and make sure there are filters on all the other phone equipment in the home
3answers
Speedstresm 5100 modem
check for physical setup between your modem and the wall jack
if u don know how exactly the physical setup is pls contact your isp for help for u to run through the steps
Speedstream 5100
The underlying Ethernet connectivity required for the broaband connection was not found. Please install and enable the Ethernet adapter on your computer via the Network Connections folder before attempting this connection.
If u don know to install the ethernet adapter pls do contact your vendor
Top Efficient Networks Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
