20 Most Recent Efficient Networks SpeedStream 5200 Modem Questions & Answers
Try Googling (SpeedStream)(5100)(manual) without parens.
Efficient... | Answered on Dec 08, 2017
If your router is connected via the Ethernet port no drivers are necessary.
If you don't have a good reason to use the USB port, please use the Ethernet since it's much faster.
Please let me know.
regards
Efficient... | Answered on Sep 09, 2013
Your modem if it is a Speedstream 5200 does not have any wireless capability and as such, there is no need for a password. You can only use one computer connected with an ethernet cable to your computer. What you can do is purchase a wireless router, preferably a N series wireless router because it is stronger than a normal G series router. Normally your modem connects to your computer via the ethernet cable. With a wireless router, instead of plugging the modem to your computer you should plug it in router. From the router you can connect another ethernet cable and plug it in on your desktop. You can connect at least 4 wired computer to your router. For the wireless part, all they have to do is look for the strongest wireless signal then hit connect. If it ask for a password then it should be in the sticker at the side of the wireless router.
Efficient... | Answered on Dec 17, 2012
Thank you for using FixYa
I am going to attempt and I say attempt to give you a solution. After much research I find that this issue has come up before since about 2003 on those series of modems. I found one solid reference that solved the issue. Their solution was to set the modem to Bridge and do the port fowarding in the Linksys router. I do not know if this will help you in your setup but it is at least worth the suggestion. I am sure your Speedstream is out of warranty by now and you are unable to get back to the supplier, who may have other suggestions. Those modems have come through an evolution of updates as you might have guessed and the solution may be getting another kind.
I hope this was useful and please comment if this was helpful to you.
Efficient... | Answered on Apr 13, 2011
Yes it will work, just be sure you connect it right.
If you need additional help let me know.
regards
Efficient... | Answered on Mar 18, 2011
regards
Hi paintballa12!
Here's the link for yor modem's userguide..
http://www2.windstream.net/downloads/links/SpeedStream211.pdf
Normally, all dsl modems can be "unbridged" byr resetting it to factory state.. But that would mean you have to save you DSL username & password again..
Check page 38 for setting modem to non-bridge mode..
Hope this helps..
Efficient... | Answered on Mar 11, 2011
You probably need to reinstall the driver.
Here is a link for you. If you do not find what you need here, please feel free to get back to me for continued research.
http://www.dslreports.com/faq/eff/4_5200#8480
Thank You for using Fix Ya! Please take time to rate this solution.
Efficient... | Answered on Sep 06, 2010
You can find the information and the firmware that you need in this link.
Hope this helps.
Kind Regards.
Efficient... | Answered on Jul 08, 2010
No it do not ahev wireless feature. details fo this devices are:-
Manufacturer: Efficient Networks Product MPN MPN 33A-5200-701 Key Features Router Functionalities dtrquestion.gif Firewall • DHCP Server Connectivity Wired Interfaces LAN Interfaces 10/100 Base-T WAN Interfaces dtrquestion.gif ATM Additional Interfaces 1 x USB Standards and Protocols LAN Standards IEEE 802.3 CSMA/CD or Ethernet • IEEE 802.3u 100 Mbps (Fast Ethernet) Protocols dtrquestion.gif ATM • DHCP • IP • PPPoA • PPPoE • TCP Routing Protocols RIP Version 1 • RIP Version 2 • Static Routing Remote Management Protocol dtrquestion.gif HTTP • Telnet • SNMP 1 Firewall / VPN Firewall Features Stateful Packet Inspection (SPI) • DoS Prevention • NAT Authentication PAP (UPAP) • CHAP Modem DSL Standards ADSL Lite (G.Lite ITU G.992.2) • ADSL Full Rate (G.DMT ITU G.992.1) Other Features LED Indicators Power • WAN • Activity • DSL Additional Features Auto Crossover (MDI/MDI-X) Warranty Warranty 1 Year Miscellaneous Release Date 2003
Efficient... | Answered on May 03, 2010
Efficient Networks SpeedStream 5200 Modem Logo
58 questions posted
Top Efficient Networks Computers & Internet Experts
pongta rajkumar
pongta rajkumar
Jeffrey Groves
Jeffrey Groves
Duncan Mutch
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SpeedStream Efficient Networks
  • SpeedStream Efficient Networks
Most Popular Question
will cisco linksys e2000 wireless router
  • Computers & Internet
