1991 Honda Accord Logo
Posted on Mar 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 1993 honda accord im try to swap a 2000 honda civic radio but my honda accord all we have for speakers cables are red blue green yellow and white,i can't figure it out wich one goes were the 2000 honda civic has 8 speaker cables
Anonymous
Level 3:
  • Master 367 Answers
  • Posted on Mar 12, 2011
Anonymous
Master
Level 3:
Answers
367
Questions
0
Helped
126315
Points
1155
All cars with 4 speakers have 8 speaker wires (4 positive and 4 negative). The colors of the wires for these two cars are not the same. The only way to know which wire goes where is to get wire diagrams for both cars. Before cutting up your wire harness, check that the radio you're installing will bolt into your car and fit. Just swapping the mounting bracket may not work.
5helpful
Stereo wiring- what colors are wat?
Thanks for using FixYa!
1992 Honda Accord Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: White/Yellow
Radio Switched 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Yellow/White
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2?
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2?
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
1helpful
Gauge cluster lights won;t light - replaced cluster, dimmer switch - did put new stereo in car? Fuses, bulbs all good. What could be the problem?
When you put the stereo in, what did you do with the red wire with a green stripe? The aftermarket radios don't always use these, so you have to wrap the ends, depending on whether or not you used a wiring harness. If that wire is shorted on the chassis, it will blow the dimmer fuse.
1995 Honda Accord Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/White
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Red/Green
Car Stereo Antenna Trigger Wire: Yellow/White
Car Stereo Amp Trigger Wire: Violet/Red
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Car Audio Rear Speakers Size: 6 1/2?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
2helpful
1987 honda accord need the color codes for radio wiring harness?
hi
Car Radio Battery Constant 12v+ Wire: White/Yellow
if my information was useful please vote me
2helpful
I need the radio wiring diagram for 88 honda civic hatchback
1988 Honda Civic Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: White/Blue
Radio Switched Ignition 12V+ Wire: Yellow/Red
Radio Illumination Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: N/A
Radio Amplifier Turn On Wire: N/A
Front Speaker Size: N/A
Front Speaker Location: N/A
Rear Speaker Size: N/A
Rear Speaker Location: N/A
Here can find the Stereo Wire Harness OEM Honda Civic 86 87 88 89 90 (car radio wiring installation parts)
Hope help with this.
Need stereo wire diagram for 1993 honda civic
Memory (+12v Constant) Blue/White Ignition (+12v Switched) Yellow/Red Ground (-) Black Illumination Red/Black Dimmer (none) Power Antenna Yellow/White S p e a k e r s Right Front (+) Red/Green Right Front (-) Brown/Black Left Front (+) Blue/Green Left Front (-) Gray/Black Right Rear (+) Red/Yellow Right Rear (-) Brown/White Left Rear (+) Blue/Yellow Left Rear (-) Gray/White
I need the diagram for the audio cables
do u mean the radio connector? if so here it is.
Radio Constant 12V+ Wire: Blue/White
Radio Dimmer Wire: n/a
Front Speaker Size and Location: 6 1/2′ Doors
Rear Speaker Size and Location: 6′ x 9′ Rear Deck
3helpful
1991 honda accord radio wires cut need schematic
Radio Constant 12V+: Blue/White
Radio Switched 12V+: Yellow/Red
Radio Ground: Black
Radio Illumination: Red/Black
Radio Dimmer: n/a
Radio Antenna: Driver’s Pillar
Front Speakers Size and Locations: 5 1/4′ Doors
Left Front (+): Blue/Green
Left Front (-): Gray/Black
Right Front (+): Red/Green
Right Front (-): Brown/Black
Rear Speakers Size and Locations: 6 1/2′ Side Panels
Left Rear (+): Blue/Yellow
Left Rear (-): Gray/White
Right Rear (+): Red/Yellow
Right Rear (-): Brown/White
LOOKING FOR WIRING DIAGRAM FOR STOCK HEADUNIT
Radio Constant 12V+ Wire: White/Green
Radio Antenna Trigger Wire: Yellow/Green
Left Front Speaker Wire (+): Green/Black
Left Front Speaker Wire (-): Light Green
Right Front Speaker Wire (+): Green/Yellow
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): Blue/White
Left Rear Speaker Wire (-): Blue/Black
Right Rear Speaker Wire (+): Pink
Right Rear Speaker Wire (-): Blue/Yellow
pls rate
4helpful
I need to find out which stereo wires are the positive and which are the negatives?
Here is the complete discription of what each wire color does. Please rate this info.
1991 Honda Accord Car Stereo Radio Wiring Diagram
Front Speakers Size: 6 1/2′
Rear Speakers Size: 6 1/2′
2helpful
How to hook up my stereo
I hqave taken the time to look this up, please take a few seconds rate the solution, thanks.
1995 Honda Civic Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
