Hello, this is Ava with Think Crucial.
You can purchase a wide variety of high quality Bissell replacement parts including your Bissell filters direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
2 Bissell Featherweight Vacuum Filters Part 2045 Fits 3204E 3105 32019
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
SOURCE: debris getting stuck in vacuum hose
Check that the filters are completely clean. If there are clogged they would have to be washed and then dried to room temp (or a low temp tumble dryer, put the filters into a pillow case with a towel and install into the machine) Tip the bissell backwards to make sure the bottom bin is pushed and locked all the way in. Only when the two seals meet will you know that the bin has locked in properly. Unhook by prising the main hose at the back off to check for clogs as well as the main hose at the bottom and the main dust channel at the sole plate where the roller bar is. You may have to remove the bottom plate to check for any obstructions behind the brush bar.
I have the Easy vac myself. Its not an Easy machine to maintain when it gets clogged!
SOURCE: Bissell easy vac plus
Press the lock button down and forward (away from the
Canister Handle) while lifting the upper portion of the Dirt Cup
away from the Canister. The bottom box should then come out.
If you need a user manual for this model I have one and can send it to you if you email me.
SOURCE: Need replacement filter for Bissell Easy Vac Plus model 3102-0
I found a filter on GoVacuum.com It sells for 11.90 with free shipping.
SOURCE: need filter, bissell 3102-0 EasyVac
The filters can be found on GoVacuum.com for 11.90 with free shipping
SOURCE: Need instructions for Bissell Cleanview bagless
tell them to go online a search for info from manufacturer
