The only reason why it would be shredding the belt is if the pulleys were not lined up correctly. Check the allignement of the belt to make sure there is nothing kepping the pulleys from being in line. The other thing that it could be is if the roller was not rolling freely check the beater bar and make sure it is free and if not clean the inside of the end caps to be sure they are free of hair and other debris.
most likely the belt was put on the wrong side of the belt retainer clips on one of the two pullys. I've done the same thing more than once. Make sure on next belt there are no sharp edges touching anywhere and while engaged or not.
take the belt off and carefully check to see if any of the pulleys are out of line and check to make sure they spin smooth and true check for bearing wear and noise in any of the pulleys cause it sounds like simply there is a pulley out of line
Don't drive the car until you make sure the belt that is shredded is not the water pump belt. YOU could drive but the engine will overheat and have a more costly problem. Two things, if the lights are working but the car is not starting. It could be that the terminals are dirty on the battery AND if the belt that is shredded is the Alternator belt, the battery could be just down on charge. Do to things (1) Find out which belt needs to be replaced and have it replaced. (2) Charge the battery, maybe a friend has a charger, if so have them trickle charge the batter for at least 12 hrs. Less there's some other problem that should take care of it.
Mine was doing the same thing and I found that if I put it in reverse for a little while it would be ok again for a short time. I found also that it did this more often when the snow was heavy and wet which makes me think that the rubber drive wheel is getting wet and slipping. If you've brought it in to a shop and they've said that nothing could be found wrong, then it must be something that goes away by the time you get it there - water (I'm guessing).
