20 Most Recent Toro Snow Blower Ccr 1000 Belt 715381 715381 71 5381 () Questions & Answers
2answers
I have a CCR 3650 Snow Blower
Try the spring on the governor. sounds like it's not hooked up, or extremely week. I rebuild and sell these all winter. I've had it happen a few times. Runs really good! but, will ruin the motor running over speed like that. There are adjustments- some have the spring on a long flange of metal so it can be bent backwards to add tension- it doesn't take much! If the motor starts to rev up and down and up and down, add a hair more tension. It there is too much tension it will stall out when you hit heavy snow.
2/28/2022 3:13:00 PM • Toro Snow Blower... • Answered on Feb 28, 2022
Toro powerlite 98 cc 16" Mod no 38182 ser
Yes, you have a shear pin and that is probably the problem...
The shear pin often will not fall out and look like a normal piece but in fact be broken...
The shear pin usually is in the main shaft from the transmission to the auger drive...
Some are right on the auger its self...look around you will find it...
heatman101
2/18/2019 2:47:48 AM • Toro Snow Blower... • Answered on Feb 18, 2019
Cannot start Toro 1800 snowblower (electric)
Can you pull start it? If so,you may need a new starter gear,about $30,they're plastic & wear out.
12/3/2017 12:25:19 PM • Toro Snow Blower... • Answered on Dec 03, 2017
My snowblower just started back firing,why?
Snow is melting on the engine and causing the spark wiring and/or magneto to short out...
Stop blowing snow and run the engine at a fast idle for awhile to dry off the motor...then it will work again..
heatman101
1/26/2015 10:53:43 PM • Toro Snow Blower... • Answered on Jan 26, 2015
0answers
0answers
I have a toro snow blower that wont throw snow
then you need to see if the belt is still in one piece... then inspect what else would cause this issue
12/30/2013 4:32:50 PM • Toro Snow Blower... • Answered on Dec 30, 2013
No pull cord tension
The little fingers on the Starter mechanism may be stuck and not expanding. The Starter mechanism my need to be taken off, cleaned and lubricated
11/23/2013 10:36:56 PM • Toro Snow Blower... • Answered on Nov 23, 2013
0answers
Toro Snow Blower Ccr 1000 Belt 715381 715381 71 5381 () Logo
78 questions posted
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
ccr 3650 snow blower
  • Garden
