Steamist Digital Timer Temp Control BNickel TC150BN Logo
Posted on Mar 04, 2011
The system was worming, producing steam and then quit working. The key pad does not work when the start/stop pad is depressed. The system is about 5 years old.
A
Anonymous
Contact company directly for product manual and troubleshoot help from manufacturer
http://www.steamist.com/contact.htm
Steamist comes with 5 year warranty, hopefully yours is still under the line.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on Steamist or any do-it-yourself project.
Fixya is always less expensive than a service call.
Why is there No steam from morphy Richards 42247 model steam generator?
It may be calcified or have lime scale. If the heater is "gummed up", it cannot heat properly. Try using either vinegar (takes longer) or an iron cleaner. You pour it in and it breaks up the scale. CLR works quite well too. Use pipe cleaners to clear out the holes in the sole plate.
Shark Euro Pro Steamer
Hi, you could try the following steps, if you have not done so already. Some of these steps may seem like common sense, but it's for people to forget about checking the least expensive part to replace first, so if some of the steps are those that you have already tried, then feel free just to skip through to the ones you have not tried already.
  1. 1
    Make sure the power cord is plugged firmly into the outlet. The steam mop will not start if it the power cord is loose.
  2. 2
    Check the fuse box or circuit breaker connected to the outlet the steam mop is plugged in to. Replace any blown fuses. Reset any tripped breakers.
  3. 3
    Check the water tank if the Shark steam mop will not produce steam. Add water to the tank if it is empty. The mop will not make steam without water in the tank. To fill the tank, turn the tank cap counterclockwise and lift it up to remove it. Set the filling funnel into the tank opening. Pour water through the funnel into the tank until the water level reaches the "Max" fill line on the tank. Replace the cap.
  4. 4
    Inspect the microfiber cleaning pad if the steam mop is leaving water on the floor. If the microfiber pad is too wet, it will leave water on the floor. Unplug the mop from the wall outlet. Replace the microfiber cleaning pad. To replace the pad, move the latch strips out of the hooks on the mop head. Pull the pad off. Set the new cleaning pad on the mop head. Hook the latch strips onto the hooks on the mop head.
  5. 5
    Use distilled water if the steam mop is leaving white spots on the floor. Hard water may cause white spots to be left.
If none of the above work, then is it something that you purchased recently, and is new? If you did, then it could still be fixed under the manufacturer's warranty regardless of whether or not the original length of the warranty has expired. This could be due to the fact that you have received a product that has some sort of manufacturing fault, rather than it stop working through misuse by the user.
If it's a common problem, then you will more then likely be able to return it to the manufacturer and have it replaced for a new one, let alone repaired :-) - This only applies to whether or not the item is New though :-).
Hope this info helps
Apr 29, 2013 • Vacuums
X5 steam cleaner does not pump steam
Hey Shaun, I only bought mine a little over 12 months ago and the same thing has happened with little than average use. I got in contact with the company who sold it to me. They suggested I buy the hand held part and that was it. How ****. I'm going to use a household descaler
Steam escaping?
do the following step:
1) distilled water and softened produce leak , change the water
2)put water until the LEVEL
3)give time enough thermostat for heating. if you use before to HEat enough produce leak.
4)switch dial off to test the water stop leaking,when the steam setting is NOT working.
5) shake back and forth for a few time, to turn on back it is auto-off function.Can be leak when is auto-off mode
God bless you
Jul 14, 2012 • Irons
We need to depress the primary start button serveral times before the washer actually starts. We have had it replace two years ago. It seems to be contact issue.
Often key pads when subjected to lots of humidity in a closed laundry room they often stop making contact. Try taking a blow dryer, on medium heat and dry for a few minuets if it starts working then it's susceptible to moisture and indicates the control pad is not sealed.
6helpful
Tefal Pro Express - Constant Steam
Found this on another site and just tried it. Put 50/50 water and vinegar in the tank and leave it to go through on the constant steam. Give it about 5 minutes then try the button. Mine gave an extra spurt of steam at this point but still continued giving steam out all the time. I refilled with the water vinegar mix and just kept pressing the steam button and letting it go through. Eventually it fixed it and the constant steam stopped. Something to do with a piece of limescale blocking the solenoid but that's all Greek to me! Hope this helps. Kind regards.
Steamer
Take off the edge on the steam pipe, clean it and mount it again.
/Mirran
2answers
Left keypad inoperable - mostly
I would get a new one and go from there. Why play around with it?
Top Steamist Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Steamist Hardware and Accessory Expert? Answer questions, earn points and help others
