Lifesource Digital Blood Pressure Monitor - Wrist - Auto Inflation Logo
Anonymous Posted on Mar 03, 2011
I get error codes on the unit. Can you tell me what the error codes mean?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 20, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1231
Points
I AM GETTING ERROR 3 ON MY LIFESOURCE BLOOD PRESSURE MOINTOR 7 WHILEPUSHING ON START BUTTON,IT DOES NOT GO AHEAD MORE THEN FIGURE 2 & COMES BACK TO 1 & THEN SHOWS ERROR 3,CAN ANYONE,SUGGEST OR GIVE SOLUTION/REMEDY ON MY MAIL ID:[email protected] I HAD LOST OPERATING MANNUAL & WARRANTY CARD,ALTHOUGH THIS MONITORING INSTRUMENT'S HAVING LIFE TIME WARRANTY,INCLUDING CUFF. THANKING YOU.
H.M.PANDYA.
I have a window unit that isn’t puting our cold air. It shows code A5 can you tell me what that code means.
Go to the manufacture's website or a company that sells the unit and download a pdf copy of the owner's manual. Usually there is a trouble shoot section at the end that will tell you what A5 and other error codes mean.
Unit flashes code "P2". Can you tell me what this means?
Can you tell us what brand of unit? And a model# & serial# would help too. Most units that can give an error code have a "self diagnostics". P2 is an error code but without brand and m# there's no way to look it up
Cannon ir c3180i printer prompting e000021-0003
This error code means that the develop unit wont rotate, although I have also had this error code when the drum unit wasn't replaced, did it tell you to replace the photoconductor?
5helpful
3answers
Canon ir 7086 error code e00005-0010
give me the solusion of error code 225 of machine cannon 7086
reply plzzzzzzz
3answers
My iR2016 displays "system error E007, would you please help me repairing it?-
it error code means fuser unite problem please change fuser unite then solve your problem
2answers
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
13helpful
3answers
Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Error code OA
Error code "OA"....machine thinks it has a faulty Laser unit. You can try a reset ( Menu, *,M..press ENTER.) if it resets GREAT.
If not and the code comes back,most likely Laser unit is defective.
Expensive and time consuming repair.
7150C Error Code #54
This error means your purge unit is not working. Most likely there is a piece of paper stuck in the unit (or other object).
You will have to take the unit apart and check for objects inside that should not be there. Also, check to make sure the excoder strip is seated correctly in the printhead (this is a long clear strip that goes from one end of the unit to the other).
If neither of these fixes the error, then the purge unit would have to be removed, inspected and repaired or replaced.
Ricoh CL2000N Error Code SC230
The manual says this code means " BCU Received no Feedback from LD" I have no idea what that means, but maybe it will help a tech on hear tell you more.
Top Lifesource Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Lifesource Health and Beauty Expert? Answer questions, earn points and help others
