Mitsubishi WS-65513 65" Rear Projection HDTV Logo
Anonymous Posted on Aug 26, 2017
My mitsubishi ws-65513 picture makes a pop noise then goes out with the sound but can still see video source info on corner of screen. then i have to turn tv off wait a couple of seconds then back on then tv will work for a shourt time before picture goes out again. i have looked at the four caps on the Dm board they dont look faulty or bulging but dont know if that is the problem
  • Anonymous Mar 04, 2011
    update: i have just replaced the four caps on DM board they wr cheap just in case the old ones didnt look bad but replaced them anyways. but the screen still makes a pop noise and goes blank and the video source comes on then. so then i disconnected the front control like some of the posts said for faulty buttons and still have same issues. can any one help me out? please
    update: also i forgot to add that when picture goes out but and the video source info is on blank screen the green light comes on solid green (not blinking like all the other post say)
richie46
Level 3:
Top Expert:
  • Mitsubishi Master 12,962 Answers
  • Posted on Aug 26, 2017
richie46
Mitsubishi Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2946374
Points
58151
If you have the time you might just want to measure them with a cap tester. It is not uncommon for a bad capacitor to look beautifully new.
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Jul 14, 2007
SOURCE: Mitsubishi ws-65513
Have you looked at the DM board fix yet that's available here. http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Check it out. If the inside of your TV set does not look like this, you will need to get the service manual to disassemble the set and get to the DM board, but use the rest of the guide to repair the board. If you are successful, you will save almost a 1000 bucks! Good Luck
Vista Electronics
  • 1694 Answers
  • Posted on Nov 05, 2007
SOURCE: mitsubishi WS-55513 won't turn on
Two choices =
1) Replace DM MODULE. 650.00 is right.
2) Rebuild DM MODULE. Done right = a little less than Mits.
Caution: High degree of skill needed and ask about warranty
in either choice.Rebuilds usually cover only parts installed,
not complete module.If you do the research on repair,you
will find pin push reset does not work,in most cases....T.
Anonymous
  • 1153 Answers
  • Posted on Jan 14, 2008
SOURCE: Mitsubishi WS-48613 No Video
If you have no video and audio then IC9c25 on Sig. Bd.
A
Anonymous
  • Posted on Jan 30, 2008
SOURCE: constant green blinking light Mitsubishi tv WS-65513
Hello all. I have fixed my green blinking light problem on my Mit. 65513 rear project. hdtv. It is on now as I'm writing. I replaced 4 capacitors on the DM board (largest vertical standing board). I used a desolder tool from RS($15).I practiced on a discarded board first. I replaced the caps with 4 radial capacitors rated 1000uf 16v. 105 degrees c and was sure to match the polarity markings on the board(+/-)with the markings on the capacitors. That's it! I also installed a small 12v PC fan(wired to a 12v wall adapter) on the DM module casing with zip ties. You may also use 1000uf 25v 105c caps. I hope this helps-good luck!
Anonymous
  • 1153 Answers
  • Posted on Mar 13, 2008
SOURCE: Mitsubishi WS-65611 Blinking lights.
You are probably talking about the FMT board. I think you can have this board repaired at PTS 18008447871
2helpful
Mitsubishi WS-65513 65' The red keeps going out
It could be a loose component video cable, check your TV menu or another device when it goes out. If you have red in the menu or other device, it cannot be your CRT. The Crt is somewhat hard to replace but if everything goes great it isn't too bad. I usually mark all the yokes and magnets with a marker so I can put them right back in the same place and the picture should be about the same. Sometimes you need to do a lot of adjustment and that is when it can get tricky, kind of depends on how "identical" the new CRT is to your old one.
Let me know how I can help
2helpful
2answers
Wavy picture
It looks like you have a convergence problem here, probably a defective convergence IC.
1helpful
No Picture after Wii Play: 65'' Mitsubishi HDTV 1080 (WS-65511)
mmm try this.... do u guys have the yellow white red cables hooked up to the front of the tv from the wii console? try loosening them up. worked for me. let's see how long it lasts .... !!!!
1helpful
5answers
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
2answers
Manual and repair instructions for mitsubishi WS-65513
You can get the V23 DM repair kit at the following link which has the replacement capacitors and the instalation instructions on Cd which has pictures of the repair. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
2answers
Mitsubishi ws-65807 no sound or picture
Check for coolant spill in corner of signal PC board = from leaky
CRT seal = bad CRT...........................T.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
