Bosch 24 in. SHE44C05UC Stainless Steel Built-in Dishwasher Logo
Posted on Jan 16, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a bosch she44c05uc dishwasher that get stuck on 1 and won't finish. The water will pump out when I cancel. The water will pump in but won't heat up. The final heating doesn't seem to work also. I have removed the circuit board and there appears to be NO solder issues. What else can it be?
Mai Lor
Level 3:
Genius:
  • Bosch Master 2,558 Answers
  • Posted on Jan 16, 2018
Mai Lor
Bosch Master
Level 3:
Genius:
Answers
2558
Questions
0
Helped
525397
Points
7053
Fix what you see then try to see what it does before go any further.
Good luck
mai
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Mar 01, 2009
SOURCE: Bosch built in dishwasher shu4302uc
There are no adjustments for cycle timing. What does affect timing is temperature of the water coming into the DW. The hotter your supply water, the shorter the time to cycle, BUT if your water is too hot, the cycle time may become too short to light the NSF 'Sanitize' indicator. But since the cycle is taking so long, this is an indication that the DW's water heater is not heating the water hot enough to advance the countdown timer in a timely manner. The control logic is waiting for the temp to come up to an appropriate level to ensure adequate washing, rinsing or drying times. Likely your display is showing '1' for a long time as a symptom of this problem, as well.  - This link http://www.applianceaid.com/boschDW.html has procedures to run self-tests on various Bosch models. I suspect that you can confirm a 'heater fault' on your unit by running the self-test.  - This problem invariably relates to a 'heater fault' which has usually been traced to an open solder joint on the control board located behind the switches/indicator lights on front door. If you have a Torx driver, soldering iron & bit of solder, you can effect a repair yourself in about an hour. Otherwise, a replacement control board is required.
If you'd like to attempt replacing the control board yourself, refer to this link for part & DIY information. http://www.appliancejournal.com/appliance-parts/bosch-appliance-parts/bosch-dishwasher-control-module-266746-37/
- Else, place a service call to the tech of your choice.
Anonymous
  • 10865 Answers
  • Posted on Aug 02, 2009
SOURCE: remove the top from free-standing-dishwasher bosch sgs43c12
hello martin - yes you can remove the top. And no, it will not harm the dishwasher funcion.
Anonymous
  • 457 Answers
  • Posted on Feb 26, 2010
SOURCE: I have a Bosch SHE44C05UC/43 dishwasher about 2.5
you must change the module. that will solve your problem. let me know how you made out.:)
Anonymous
  • Posted on Mar 06, 2010
SOURCE: Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Anonymous
SOURCE: Bosch 24 in. SHE44C05UC pops breaker
We just had a potentially dangerous problem with the same model. Only we found the wiring beneath the front door were fried. How do yours look?
Bosch dishwasher counts down to 001 and stops can not cancel the 1 minute left
Very common"no heat" error for bosch to stay at 1 min. If the water doesnt get hot enough, it will never finish cycle
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Bosch dishwasher she44c05uc won't drain
If there were 2 seeds, are you positive there are no more? Try flicking the impellor by hand, if it moves then check for voltage at the pump when running. If no voltage, then pcb, if voltage then pump
Model she44 won't drain
If nothing obvious like blocked / obstructed outlet pipe
You need to check if the outlet pump motor in line with the outlet hose is spinning when in the outlet mode. First check if it is spinning by looking at it and see if the small fan is spinning. If it is turnning this means that it has power and the internal "impeler" that pushes the water out has become loose. Remove the pump (easy job) and repair. If it does not spin you need to determine if the 2 push on terminals have power on. If there is voltage and the motor does nut spin this indicates that the pump motor is open circuit and must be replaced.
1helpful
Bosch Dishwasher Water Not Heating
Depends on if it is the controller board (easy, just behind the door and requires a torx 20 screw driver) or if it is the heating element. The latter is easy, but time consuming, as it requires you to pull the dishwasher out, detach the bottom, tilt it on it's back, and remove pump,etc to get to it. Not difficult, just a bit time consuming.
2helpful
3answers
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Power fine, but no water filling the tub
difficult not seeing the valve firsthand but if you could connect a tester to the solonoid and confirm that there is power on the terminals, then you know there is an issue with the valve. typically, if you have a leak, it to will raise the float and shut off the valve.
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
