20 Most Recent Bosch 24-in Built-In Dishwasher Color: White ENERGY STAR SHE43RF2UC Questions & Answers
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out. See this discussion. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
4/5/2014 7:47:36 PM • Bosch 24-in... • Answered on Apr 05, 2014
2answers
Bosch dishwasher start with CL code
That is just saying the Child Lock (CL) has been activated.
Deactivate the child lock ' Bosch
Bosch Home https://www.bosch-home.com > ... > Get support 1. Press and hold the start button for three to five seconds ... When the child lock is activated, there will be a message "CL" in the display and all the washing ...
Bosch dishwasher child lock problem
Bosch-home.co.uk https://www.bosch-home.co.uk > ... > Dishwashers Hold down the lock button for three to five seconds. You should hear an audible beep and/or see the symbol disappear. The child lock is now deactivated.
What does CL mean on a dishwasher? And how do I fix it?
Quora https://www.quora.com > What-does-CL-mean-on-a-dish... This code means that the CHILD LOCK or CONTROL LOCK feature has been activated. When activated, all buttons will not change except the washer's door and the ... 9 answers · Top answer: First, look on your dishwasher to find a label that shows the manufacturer and the model number. ...
How to turn off the CL on the display of a bosch dishwashe...
JustAnswer https://www.justanswer.com > Appliance Repair Oct 28, 2010 - You should just be able to just turn the power button off, then turn it back on and the CL should be gone. 1 answer · Top answer: Hello, and thank you for using this service. I'll be helping you with your ..https://www.youtube.com/watch?v=Xr4DBwACUW4
4/15/2024 10:37:04 PM • Bosch... • Answered on Apr 15, 2024
Water dripping out of last hole in Bosch upper spray arm getting dishes below wet
the unit could be un-level
3/22/2024 4:43:03 PM • Bosch... • Answered on Mar 22, 2024
Model shy56ao5uc/23. How can I turn off alarm?
YOU CAN ONLY LEARN TO ATTEND TO IT WHEN IT SOUNDS . THEY HAVE NO FEATURE TO TURN IT OFF OTHERWISE
3/4/2024 11:14:58 AM • Bosch... • Answered on Mar 04, 2024
2answers
Bosch dishwasher error code c1
HiPump-out not accomplished in normal time.Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
1/20/2024 2:53:57 AM • Bosch... • Answered on Jan 20, 2024
I have a Bosch SHE58C. What is making this noise?
This is the parts schematic that shows all the parts and where they are located. The noise is either something stuck in the pump or a dry bearing. https://www.searspartsdirect.com/model/25b4iqte9a-001794/bosch-she58c02uc-50-dishwasher-parts ..
1/18/2024 1:01:01 AM • Bosch... • Answered on Jan 18, 2024
3answers
Will a new Bosch dishwasher fit into the space of my 20-yr-old Bosch dishwasher?
Dishwashers come in standard sizes. Your old one is 60 CM wide and made for built in. https://www.bosch-home.ca/en/supportdetail/product/SGU4025AU/31 DISHWASHER 60 CM BUILT-IN/BUILT-UNDERSGU4025AU/31 As long as the new one is also for built in, the dishwasher will fit. Measure the height of the space you have. There may be a little height adjustment on the feet. ..
1/3/2024 11:11:40 AM • Bosch... • Answered on Jan 03, 2024
Bosch dishwasher leaking on the back
AI Bot Answer Deleted. In the base of the dishwasher above the floor there is a plastic tray that has a leak sensor. If you see water behind the machine than it means you have a 'spraying leak' as the sensor cuts off the machine as soon as it is triggered. It is likely to be a leaking hose on the pump. It can also be caused by the machine over-filling. An E15 error code indicates that the safety switch has detected water in the base of the dishwasher. Your leakage protection system has activated. What can I do to fix the E15 Error Code on my dishwasher? Please turn off the water inflow and contact Bosch Customer Support for assistance.
E15 Bosch Dishwasher Error Code
8/27/2023 3:43:43 PM • Bosch... • Answered on Aug 27, 2023
Bosch dishwashers E 24 erro code.
8/15/2023 10:21:48 AM • Bosch... • Answered on Aug 15, 2023
My Bosch SMS6HCI01A makes a sound on closing door
8/15/2023 10:14:52 AM • Bosch... • Answered on Aug 15, 2023
Bosch SHU66C05UC/40 is not cleaning dishes and leaves film
It needs descaling. Try CLR in a wash
7/25/2023 4:52:38 AM • Bosch... • Answered on Jul 25, 2023
Bosch SHU66C05UC/40 is leaving white film on the dishes.
Add some salt.
7/24/2023 7:52:04 PM • Bosch... • Answered on Jul 24, 2023
I am not getting water into the dishwasher after changing the inlet valve
Check if there is anything in the large item trap or blocking the water level sensor. The dishwasher won't try to fill if it believes it is full. Try pressing and holding the Start button for 3+ seconds. The Clean LED should light up in a minute. If it does, try the on/off button and starting a new cycle. (This just clears any old programs from the memory.) Some washers will stop if they detected a water leak. Sometimes turning off the power for a while and checking for water in the cabinet below the dishwasher or in the motor area is useful. The more likely items to check: Check the wiring between the inlet valve and the control board. Check the wires for corrosion at the connecting pins and for continuity. Broken conductors don't send a signal to open and close the valve. If those are okay, then the control board itself may be faulty. Since this dishwasher is discontinued by the manufacturer, I don't know if all of the parts are still available. The only parts list for the SHE3ARL2UC/28 that I found is here: https://www.partselect.com/Models/SHE3ARL2UC/ . They don't list any wires or the control board. I hope this helps. Cindy Wells
7/9/2023 9:13:29 PM • Bosch... • Answered on Jul 09, 2023
Bosch dishwasher wont start
The water supply is inadequate for your dishwasher.
4/29/2023 6:31:03 AM • Bosch... • Answered on Apr 29, 2023
Bosch built in microwoven error E 3 how to fiend the problem
If you're seeing an E3 error on your Bosch built-in microwave, it usually indicates an issue with the touchpad or control board. Here are some steps you can take to try to fix the problem: 1. Unplug the microwave: The first step is to unplug the microwave from the electrical outlet for at least a minute. This will reset the control board and may clear the error code. 2. Check the touchpad: Sometimes, the E3 error can be caused by a stuck or malfunctioning touchpad. Check the touchpad for any damage or debris that may be interfering with its operation. Clean the touchpad with a soft, damp cloth and make sure it is completely dry before plugging the microwave back in. 3. Replace the touchpad: If the touchpad is damaged or not working properly, it may need to be replaced. Contact a Bosch authorized service center to order a replacement touchpad and have it installed by a qualified technician. 4. Replace the control board: If the touchpad is not the issue, the E3 error may be caused by a faulty control board. Again, contact a Bosch authorized service center to order a replacement control board and have it installed by a qualified technician. In any case, if these solutions do not work, it's best to contact a qualified technician to diagnose and repair the issue, as microwave repairs can be dangerous due to the high voltage involved.
4/26/2023 4:42:30 AM • Bosch... • Answered on Apr 26, 2023
Bosch Dishwasher. I need black touch up paint for the front of my dishwasher please?
https://www.reliableparts.ca/catalog/Touch-Up-Paints-467065 and Amazon of course!
Black Appliance Touch Up Paint
Amazon.com https://www.amazon.com > black-appliance-touch-up-... Rust-Oleum Paint 213174 .6-Ounce Specialty Brush Bottle Appliance Touch Up, Black, 0.6 Ounce. Enamel, Acrylic, Specialty. ..
4/22/2023 11:50:36 PM • Bosch... • Answered on Apr 22, 2023
Spray arm hits plastic water supply as it spins, making a banging noise
I had this exact problem. There is a single hole on the underside of the arm, and it seems like the jet from it is enough to lift the arm so that it clears the plastic. The hole was clogged for me. Still have some thumping noise but it's 1/10th of what it was before.
4/17/2023 8:24:07 PM • Bosch... • Answered on Apr 17, 2023
2answers
Bosch SHX45P05UC/60 dishwasher all cycles got a lot longer!
The senors for your dishwasher are either dirty or need to be replaced.
4/15/2023 7:55:41 PM • Bosch... • Answered on Apr 15, 2023
Bosch SHS5AVF6UC/22 Dishwasher. What does it mean if the dishwasher won't start and it beeps 5 times while the sanitize light is blinking?
I have a Bosch Silence Plus 46 dBA. SHS5AVF6UC/22. ...
JustAnswer https://www.justanswer.com > Appliance Repair Jul 5, 2021 - What have you tried so far? When I try to start the cycle, the red light on the floor comes on, it beeps, but won't start. 1 answer · Top answer: Hi and welcome to Justanswer. My name is ***** ***** to assist you today. I'm Why is my Bosch dishwasher beeping and not starting? Bosch dishwashers are designed to beep when there is an error. A beep means that your drain is not clogged, and the rest of the parts are functioning as they should. Beeping in the middle of the cycle points to the problem with the control board itself. Find the circuit breaker and turn it off for 60 seconds.
Bosch Dishwasher Error Codes ~ By I-Fix Appliance Repair
4/8/2023 2:09:19 AM • Bosch... • Answered on Apr 08, 2023
Bosch dishwasher stops working correctly -
3/24/2023 4:45:04 PM • Bosch... • Answered on Mar 24, 2023
Bosch 24-in Built-In Dishwasher Color: White ENERGY STAR SHE43RF2UC Logo
1 questions posted
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dishwashers
  • Bosch Dishwashers
Most Popular Question
motor keeps running water heats fine
  • Dishwashers
