If you're using a laptop then look for the key that sends the image to the projector. Usually you have to connect the cable between the computer and laptop with both units powered down. That way when the PC boots it will see the projector is connected.
Look for the F-key with a square/icon of a laptop. Press FN+This button until you see your screen display show that it will be using your LCD + the output on your computer. Remember you need to hook both the VGA or HDMI out to the projecter as well as the USB cable.
try to use a full wired VGA cable, so the laptop can recognize the external display/ projector by the ID pins.
Many laptops deactivate external display ports to save energy
make sure the laptop is plugged in and not on battery. also make sure the dmi-vga cable is not too long. the signal isn't strong enough to get to both screens.
Are you saying that the projection is solid blue? Is it similar to, say, the desktop on the laptop screen? Try moving your mouse off to the right side of the laptop. Did it show up on projector? Exciting! Try dragging stuff over. Damn, this is sweet.
i suggest you do not have the projector too far away... 7ft away distance would be a Good resolution will also dimm don the square's image in the picture
