SOURCE: when sending a text msg, it goes to outbox, wont send
I had the same problem and I read on down and saw someone's phone was stuck in flight mode. I remembered that for some reason, my phone was in flight mode the other day, so I went in and took it off. I realized the problem had been since that time. So, I put the phone back in flight mode and was able to delete the message from my outbox. I put it back in normal mode and now I can send texts. Yes!!!!
SOURCE: inactive sim
This is a known design flaw with the w760i - it occurs when the phone requests info from the SIM (building contact list etc.) and the SIM connection is lost. This would happen on any phone but the w760i has a shock protection design issue whereby closing the slide quickly causes the SIM to disconnect. You should be able to replicate the issue by turning the phone on and slamming the slider shut as soon as the phone shows your network name. Leave the phone on for a bit and you will feel the phone buzz and 'Inactive SIM' will display, the phone will then reboot.
SOURCE: text messages going straight to outbox.
YES! go into your outbox and select the stuck message to move to drafts, then shut off your phone and turn it back on, problem should be solved. worked for me!
SOURCE: cant send text messages with my sony ericsson satio.
that happend to me so i sold it to mobile phone exchange n got £152
SOURCE: My phone won't seem to send text messages. When i
chk msg centre number,sent msg as text shud b there,msg validity shud be maximum,and reply via same centre shud be no in settings..chk these settings in ur message settings..
