I can not get a reading on the outside temp and humidity. I changed the batteries I have the springfield precisetemp base station 433 mhz wireless. Thanks Don Haag
Sound like the reset switch is bad... If I was you mite go to your nearest truck stop and ask around to see if there is a radio guy that mite change it for you.
Hi, Jackie.
Is it look like this ?
With Windspeed and 3 station temperature reading ?
If so, model number is 91751
Good luck with finding Manual.
I have paper manual with me, I can scan most useful pages for you (Buttons)
SOMETIMES WHEN METAL IS IN DIRECT SUNLIGHT IT WILL GIVE FALSE READING. MY OUTDOOR THERMOMETER IS METAL AND IT READS ABOUT 15 DEGREES HOTTER THEN IT IS. BECAUSE IT'S IN DIRECT SUNLIGHT.
You shoud use new batteries because you dont know how old the ones that are present are. You should also use lithium battteries in the weather station sensors because they last longer and have better low temp response. The batteries should have marks on them that correspond with the marks inside the sensors.
