Hello there and thank you for choosing fixya
Sud
SUDS (Overdose
of Detergent detected during the Wash Cycle)
The motor control
unit senses a suds lock condition by analyzing the current draw on
the drive motor. If "Sud" is displayed a potential suds
lock is detected. This may signify a bad pump, an extra heavy
load, excessive detergent, or excessive suds.
If too much detergent was used,
run the unit through a Rinse/Spin cycle, then a Normal cycle,
without adding any detergent. This should clear the unit of
the excess detergent.
Check the drain hose and make
sure it is not plugged or kinked.
what does SUD mean in - globul1a.gif"/uploads/images/globul1a.gif" alt="globul1a.gif" class="h_mi" />
Check Wire Harness connectors to
the Drain Pump, Pressure Switch, and Central Control Unit (CCUwhat does SUD mean in - globul1a.gif
Check/Clean Drain Pump Filter of
what does SUD mean in - globul1a.gifreign objects
Check Drain Pump
Check Pressure Switch
Check CCU
SOURCE: My Kenmore Elite Front load washing machine HE4
SuD = SUDS referes to the Pump strainer. It needs to be accessed by taking off the front to get to it and be cleaned
There are 3 screws on the bottom panel you need to remove. Take off
panel. Facing you is the pump strainer. Big white piece of plastic.
It is the only thing you can unscrew by hand.You may be surprised as to what you find in there. Good hunting.
Please rate my help++++Thanks for using FIXYA
