SOURCE: Omron HEM 650 Wrist Blood Pressure
There are some instructions at this site. It was enough to get me going...
http://www.targetzone.net/HEM-650.html
SOURCE: User manual for omron hem 403c blood Pressure monitor
this is the website for Omron Healthcare product manuals where you can find your model number and download or view the manual and even print it out if you want. good luck and God bless!!
http://www.omronhealthcare.com/product/manuals.asp
SOURCE: Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Testimonial: "Sound advice."
SOURCE: My Omron HEM-712C digital blood pressure monitor
First, I do not believe there is any accurate way to measure blood pressure without having a valve installed; not a practical alternative.
The standard method using an arm-cuff and stethoscope is highly dependent on the person doing the measurement. Once my hearing started to fail, I had to go to a digital meter and found after three of these which failed and comparing my current Samsung to three different methods; manual, an elaborate 'calibrated' digital on a stand and another 'calibrated' cuff-type during an examination by a professional, none of these agreed better than 10-15 mm and the worst was 25-30 mm apart.
Using the average of those 'profis,' my current wrist-type digital measures about 10 points low on both systolic and diastolic so I just ignore the absolute numbers and use it only to determine relative deviations.
For that, mine is repeatable enough.
